<1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question: module_types.h
Date: Tue, 2 Aug 94 09:44:52 MDT
> 	I'm in the process of trying to add a VME driver to module_types.h
> and seem to be running into problems. Can anyone tell me where to look for the
> definitions of MT_DEF_PARM and MODULE_TYPES_INIT?
The C macro MODULE_TYPES_DEF facilitates the inclusion of module_types.h
into many source modules without allocating storage for the variables
declared within in all of these modules. The parameter MODULE_TYPES_INIT
is defined in the single source module that allocates storage for the
parameters.
MT_DEF_PARM is a parameter to the macro MODULE_TYPES_DEF(MT_DEF_PARM)
which is defined in module_types.h.
For example the definition:
#define MODULE_TYPES_DEF(MT_DEF_PARM) extern MT_DEF_PARM;
MODULE_TYPES_DEF(short ai_num_cards[MAX_AI_TYPES+1])
results in:
extern short ai_num_cards[MAX_AI_TYPES+1];
> I'm having problems adding a
> 13th module. I add the appropriate information to the ai lists (address, number
> of cards, etc...), but it seems to ignore it and instead set the value to the
> first entry in the successive list.  (and yes, MAX_AI_TYPES is set correctly
Most likely your problem results from share/src/db/iocInit.c
needing to be recompiled. This is the one module
that defines MODULE_TYPES_INIT.
It is also possible to modify __existing__ parameters by making
changes to a private copy of share/src/drv/module_types.c.
Recompile this module and reload it after you load iocCore. Next, call
the module_types() entry point from the vxWorks shell just prior to calling
iocInit from the shell (module_types() isnt called by iocInit).
I will add a short section on this source of confusion to the
"writing a device driver" notes that I am preparing.
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM USA 87545	FAX		505 665 5107
Prev: Question: module_types.h LUCAS
Next: Granville-Phillips VG-307 vs GPIB Bill Brown
Index: <1994>  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
