Subject: |
Re: EPICS and Solaris 2.x |
Andrew Johnson <[email protected]> |
Date: |
Wed, 18 Jan 1995 21:12:00 GMT |
On Wed, 18 Jan 1995 11:06:47 -0700 Low Master Kim wrote:
> I have worked on porting the first beta 3.12 EPICS to Solaris 2.4.
> My approach was to make the changes required to get the source to compile on
> the Solaris machine with the Solaris libraries and includes. It
> is my view that using the ucblib and ucbinclude files as Andrew reports is
> _not_ a port of EPICS to Solaris - it is making do until a real port is
> done. I think it is important that the Solaris port not rely on the
> compatibility libraries which may eventually go away. I would urge the
> system maintainers not to distribute a Solaris EPICS that needs the ucb
> compatibility libraries.
I disagree, initially at least - why shouldn't we use this code, it's there to
allow existing programs to be compiled with only minimal changes. While it may
be desirable eventually to get away from using the ucb compatibility libraries,
I felt it was more important to produce something which would build and run on
the Solaris systems we have today, without taking up too much effort. By keeping
the number of changes in the sources to a minimum I could be more confident of
not introducing additional bugs myself. Reliability should be more important
than "religion" where software is concerned.
In fact I started out by doing the full SVR4 conversion, but I felt that
initially we should release something which works with as few changes as
possible, so I removed the unnecessary mod's when generating the patch file I
sent to Janet (having checked the "un-changes" didn't break anything).
> ... The list of
> changes Andrew has is mine it is just notes I made to myself and doesn't
> include diff files, etc.
This is not true - I received Kim's list of changes after I had already
converted base and some of the extensions to use the SVR4 libraries. Some of his
changes (eg to the RULES files) are not portable and would break compilation
under SunOS, and maybe under the other architectures as well. This would
obviously not be acceptable in anything which is to be released to the whole
consortium, thus he has a fair amount of work to do before he could incorporate
his version into the release.
- Andrew
,_}\_. Andrew Johnson, Technology Division
/ \ Royal Greenwich Observatory
~~~~~~~~| ,--/;. )~~~~ Madingley Road, Cambridge, UK
., |/ (/ U Phone: +44 (0)1223 374823
.`., /_\ . . Email: [email protected]
wwWWWww' WWW: http://cast0.ast.cam.ac.uk/~anj/
Re: EPICS and Solaris 2.x mcgehee
Re: Status of PC Based EPICS Work Carl Dickey
<1995>
<1995>
