Subject: |
Re: More than 1 output link |
[email protected] (Steve Lewis) |
Date: |
Wed, 24 May 95 20:50:00 PDT |
> >Does anyone know how to add more than 1 output link to a record?
> Unless the record supports it, you will have to use something like the sequence
> record. It was designed to fetch values and then put them elsewhere (It has a
> group of link pairs in it.) It was also designed to allow a delay between each
> transfer if you want... zero is an allowable delay.
> So then, you could point each of the inputs to the same place and all the outputs
> to... whereever and use a delay of zero, and get the effect you describe.
You might find the dfanout record more useful. Point the single DOL at the incoming
value, then point the many OUT links as needed. Be sure to set the mode to "closed
loop."
Steve
Re: Postscript Documentation, Whoops! Tim Mooney
Re: Postscript Documentation Ian Smith
<1995>
2025
Re: More than 1 output link winans
Postscript Documentation Stefan Hippler
<1995>
2025
