1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: application directories and CVS, GNU make etc
To: tech-talk@phoebus
Date: Fri, 9 Jun 1995 09:21:51 -0500
Just a couple of comments.
1) Keep the dialog going. In the end we all have very similar problems.
2) The app source/release system designed and implemented at APS had
   a LOT of discussion before it was built. It is being successfully used.
   The fact that people are still dissatisfied with it shows that this is
   a tough problem.
3) Johnny Tang looked very hard at what we have done before making changes.
4) I hope that the end result is a single (documented) Application
   Source/Release system that we can all use.
At APS, at least for now, we will continue to use the existing system.
Our Application Developers have adjusted to it. Thus we have the luxury
of sitting back and seeing what is developed by others.
One other warning. We have started working on getting rid of default.dctsdr
and the associated build utilities. All info will be read via ascii files.
One additional goal is the ability to allow each database and ioc to load
only the record types, device support, and driver support it uses.
Thus the existing requirement that all users of an application development
environment have to share the same set of ascii definition files will
disappear. In a few weeks there should be a document that gives more details
about what is being proposed. A lot of thought will have to be given to
"packaging". Whatever is done will impact App Source/Release systems at least
to some degree.
Marty Kraimer
Prev: Re: application directories and CVS, GNU make etc Johnny Tang
Next: Re: application directories and CVS, GNU make etc William Lupton
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: application directories and CVS, GNU make etc William Lupton
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
