1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Solaris 5.x changes to blderrSymTbl
To: Michael Bordua <[email protected]>
Cc: EPICS Tech-Talk list <[email protected]>
Date: Fri, 16 Jun 1995 09:42:39 BST
Mike,
On Thu, 15 Jun 95 18:01:58 PDT Michael Bordua wrote:
> In the process of setting up one of the STAR people on EPICS for
> Solaris, I had to make the following change to
> base/tools/blderrSymTbl:
If you look at Beta13 you'll see that I already fixed this, and in fact Nick
Rees added to my changes as well since.  It now uses a case on the configured
HOST_ARCH to split up the different architectures, and with Nick's changes it
can also take the HOST_ARCH as a parameter.  I'm not sure if Janet has applied
Nick's changes to the repository yet, but the Beta13 version works in normal
circumstances (it fails if you are using multiple host architectures and you run
it on a different architecture to the HOST_ARCH setting in CONFIG_SITE).
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_	Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__	Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Prev: Solaris 5.x changes to blderrSymTbl Michael Bordua
Next: Re: Building for more than one host architecture Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Solaris 5.x changes to blderrSymTbl Nick Rees
