1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Building for more than one host architecture
To: tech-talk@phoebus
Date: Fri, 16 Jun 1995 07:31:49 -0500
> From [email protected] Thu Jun 15 21:26 CDT 1995
> Date: Thu, 15 Jun 95 19:26:50 PDT
> From: [email protected] (Michael Bordua)
> To: [email protected], [email protected]
> Content-Type> : > text>
> Content-Length: 1588
> At LBL we address the above problem by building base and extensions in
> the same sub-directory and then linking to both base and extensions in
> the appication areas.  That way if there is some weird dependancy to a
> version of either base or extensions then there is no problem.
Just some additional comments about problems with extensions.
When an application is large, i.e. many iocs and many developers, there will
be periods when iocs are on different releases. This is typically the case
when converting to a new release. In general not all developers are prepared
to convert at the same time. Thus we have extensions users that are talking to
collections of iocs that are using a combination of releases.
This is why Jeff has worked so hard to keep the Channel Access protocal
backwards compatible. When the day comes that the CA protocal is changed
so that backwards compatibility is not supported it will mean that entire
applications must change to the new release. For example at APS it will mean
that all iocs and all extensions products will have to be changed at the
same time.
One last comment. Many users and developers are only involved with extension
products. Thus they dont know or care about base other than that their
extension products happen to be build against a particular version of base.
Marty Kraimer
Prev: Re: Solaris 5.x changes to blderrSymTbl Andrew Johnson
Next: Re: TTL --> fibre Bill McDowell
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Building for more than one host architecture Marty Kraimer
Next: Building for more than one host architecture Janet B. Anderson
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
