1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Fortran-CA interface
To: [email protected]
Cc: [email protected]
Date: Thu, 20 Jul 1995 12:31:04 -0600 (MDT)
	A few weeks ago there was a request for information about a Fortran
interface for the Channel Access Library.  I have developed interface routines
for use in the upgrade of the Protron Storage Ring (PSR) control system at the
Los Alamos Neutron Science Center (LANSCE).  Development of these routines
required much consultation with Jeff Hill; many thanks Jeff!
	Interfaces to the following Channel Access routines were implemented:
ca_task_initialize()
ca_search_and_connect ()
ca_array_put()
ca_array_get_callback()
ca_add_masked_array_event()
ca_pend()
ca_flush_io()
ca_add_exception_event()
A number of other routines (eg. ca_put) were not implemented because they are C
macros.
	The following utility routines were implemented:
output_message() (an interface to ca_message)
connection_handler()
exception_handler()
get_handler()
monitor_handler()
	Finally a procedure was developed to generate Fortran Include files
for ECA_, DBR_ and DBE_ parameters from the Channel Access .h files .
	If you wish documentation on these routines, send e-mail to
[email protected].
Prev: SDR files for multiple platforms greene%denali.UUCP
Next: PID record Kevin Tsubota
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Fortran-CA interface F. Gougnaud
Next: REMOTE DEVELOPER NOTICE Matthew Needes
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
