1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ca_pend_event question (VAX/VMS only)
To: [email protected]
Cc: [email protected]
Date: Wed, 09 Aug 1995 11:57:04 PST
> tc writes:-
>> Multinet (the preferred VMS TCP/IP) also provides a stub driver which emulates
>> the DEC supplied UCX driver interface, so this is a possible route (but see
>> below).
> Jeff writes:-
>I saw that also. Perhaps this is a way to deal with DEC CC's obnoxious
>involuntary replacement of recv with decc$recv. @#$%$!
Not really. This is just VMS's way of isolating name spaces in shareable
libraries. It _used_ to be that DEC "C" was an anomaly in all the supported
languages. Shared library references had to be included explicitly in the
link step. With the ANSII C and C++, DEC regularized the link step. Both
compilers prepend "decc$" to some reserved library calls, and then the link
step scans (potentially) _all_ language specific shareable libraries to resolve
the symbols. What they are attempting to do is isolate decc$recv from for$recv
and pas$recv or whatever. You can avoid this behaviour in a number of ways.
The simplest is to use the switch "/PREFIX_LIBRARY_ENTRIES=(EXCEPT=recv)" with
the CXX compiler.
>> The problem with VMS at present is not so much that the Multinet library isn't
>> thread safe, but that the VMS thread implementation is user mode rather than
>> kernel mode. One consequence of this is that send/recv block the whole process,
>> rather than the individual thread.
>Ouch. I wasnt aware of this limitation.
Rumoured to be going away in a subsequent release of VMS. Probably only for
Alpha/VMS, not VAX/VMS. Probably 6 months out.
>> I've developed code which solves this (for another project). I have jacket
>> send/recv routines which are functionally equivalent to the Multinet ones,
>> but actually block on condition variables which are then signalled by the
>> QIO completion AST. Voila! Thread safe Multinet (equivalent) routines.
>> email me if you want further information on this.
>Does this include select?
No, 'fraid not. I've never been keen on `select', and it isn't necessary in
a properly designed threaded program. However, I've just checked the
documentation and it seems quite possible to implement. The only strangeness
is that you have to issue multiple $QIO's for each channel (fd) which you
are selecting.
>> In general, however, I think it would be bad practice to allow the VMS channel
>> access routines to diverge (again) from the facilities available under Unix.
>> The goal should be to provide a consistent interface across all OS's, even if
>> this means a degree of `dumbing down'.
>Another possibility is to encapsulate the transport level calls so
>that the socket interface is only one of several OS dependent
>communication API options.
Now _that_ is the best way.....
Tony
Dr Anthony D Cox
Computer Systems Specialist
Stanford Synchrotron Radiation Laboratory
Stanford Linear Accelerator Center
MS 69, Box 4349
Stanford CA 94305
[email protected]
Prev: correction! Michael Borland
Next: CSO tickets at ICALEPCS Martin J. Knott
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ca_pend_event question (VAX/VMS only) 415
Next: BURT available on Alpha/Unix platform, but a few problems 415
