Dear all,
How do you set an initial value for an output record (ao, bo, mbbo, longout,
stringout etc)?
The current behavior of init_record() is as follows (I've taken this from
the ao record but the others all seem very similar):
1. if DOL is a constant, it is copied to VAL and UDF is set FALSE
2. if device support supplies an init_record() routine, it is called
3. if so and status 2 is returned, no conversion is performed
4. if so and status 0 is returned, normal conversion from RVAL is performed
The result is that a DOL initial value is honored only if:
1. there is no device support init_record() routine, or
2. the device support init_record() routine returns status 2
Also, if a device support record_init() routine is going to return status 0 it
should always have set RVAL to something sensible.
The issue arises: what if the database designer _wants_ to force an initial
value for a record? Currently he can't be sure that this is possible, because
it's up to device support. Should there be a means of doing this? If so,
presumably there needs to be a new "force init" field (FINI?) which says that
the DOL constant value is to be used regardless. What if you want to give a
record an initial value but want to retain the option of running it in closed
loop mode? Perhaps a field other than DOL should be used for the initial value
(IVAL? --- already used for this purpose in the steppermotor record). For
upwards compatibility, IVAL would only be used if FINI is YES.
I would propose (and I expect that this is what is happening already in most
if not all cases) that the device support init_record() should _always_ read
RVAL from the hardware and return 0 if it is capable of doing so. If it is not,
then I think that usually the best behavior would be for device support to set
RVAL to a suitable default and still return 0. With the above FINI / IVAL
scheme, the application designer can still provide his own default to override
that provided by device support.
Any comments?
William
Q: NI-1014 GPIB board with Force CPU40. Noboru Yamamoto
Re: output record initialization Gordon Uchenick
<1995>
Re: Q: NI-1014 GPIB board with Force CPU40. Noboru Yamamoto
<1995>
