Hello Together
I have the following problem with the EPICS cadef.h file:
This .h file defines the following structure
struct channel_in_use{
ELLNODE node; /* list ptrs */
short type; /* database field type */
#define TYPENOTCONN (-1) /* the type when disconnected */
unsigned short count; /* array element count */
union{
unsigned sid; /* server id */
struct db_addr *paddr; /* database address */
} id;
void *puser; /* user available area */
enum channel_state state; /* connected/ disconnected etc */
caar ar; /* access rights */
* The following fields may change or even vanish in the future
caCh *pConnFunc;
caArh *pAccessRightsFunc;
ELLLIST eventq;
unsigned cid; /* client id */
unsigned retry; /* search retry number */
void *piiu; /* private ioc in use block */
#ifdef vxWorks
void *ppn; /* ptr to optional put notify blk */
#endif /* vxWorks */
* channel name stored directly after this structure in a
* null terminated string.
typedef struct channel_in_use *chid;
and does a typedef with the name chid for this structure.
Later this name is used in two structures, for example in :
struct event_handler_args{
void *usr; /* User argument supplied when event added */
---> chid chid; /* Channel id */
long type; /* the type of the value returned (long aligned)*/
long count; /* the element count of the item returned */
void *dbr; /* Pointer to the value returned */
int status; /* CA Status of the op from server - CA V4.1 */
This gives this warning with the SUN compiler:
"./epics.3.12.1/base/include/cadef.h", line 218: Warning (Anachronism): Redefining chid after use in event_handler_args.
"./epics.3.12.1/base/include/cadef.h", line 218: Note: Type "CC -migration" for more on anachronisms.
"./epics.3.12.1/base/include/cadef.h", line 257: Warning (Anachronism): Redefining chid after use in exception_handler_args.
and even worse it is a syntax error! with GNU g++ compiler
It compiles, when the name is changed. e.g. chid chidname
Can somebody help me ?!
*** **** ** * * Olaf Hensler
* * * * * * DESY, -MVP- [email protected]
* * *** ** * Notkestrasse 85 Tel.: +49 40 8998 3372
* * * * * 22603 Hamburg FAX : +49 40 8998 4448
*** **** ** * Germany
Re: InterViews and free_gdct for Solaris jbk
Re: Epics C++ Problems John R. Winans
<1995>
<1995>
