> and does a typedef with the name chid for this structure.
> Later this name is used in two structures, for example in :
> struct event_handler_args{
> void *usr; /* User argument supplied when event added */
> ---> chid chid; /* Channel id */
> long type; /* the type of the value returned (long aligned)*/
> long count; /* the element count of the item returned */
> void *dbr; /* Pointer to the value returned */
> int status; /* CA Status of the op from server - CA V4.1 */
Olaf,
This problem has already been address and Jeff has corrected it for the
next release, in the mean time, attached is the corrected file.
Jim
-----------------------------cut-----------------------------
#ifndef INCLcadefh
#define INCLcadefh
#ifdef __cplusplus
extern "C" {
#define CAC_FUNC_PROTO
#endif
#include <shareLib.h>
#ifdef __STDC__
#endif
#ifndef HDRVERSIONID
# define HDRVERSIONID(NAME,VERS)
#endif /*HDRVERSIONID*/
HDRVERSIONID(cadefh, "@(#) $Id: cadef.h,v 1.39 1995/09/29 21:35:06 jhill Exp $")
/* auto include of all stuff that cadef.h uses */
#if defined(CAC_FUNC_PROTO) && !defined(CA_DONT_INCLUDE_STDARGH)
#include <stdarg.h>
#endif
#ifndef INCLdb_accessh
#include <db_access.h>
#endif /* INCLdb_accessh */
#ifndef INCLcaerrh
#include <caerr.h>
#endif /* INCLcaerrh */
#ifndef INCLcaeventmaskh
#include <caeventmask.h>
#endif /* INCLcaeventmaskh */
#ifndef INCLellLibh
#include <ellLib.h>
#endif /* INCLellLibh */
* NOTE: the channel in use fields type, count, name, and
* host name are available to applications. However it is
* recommended that the following MACROS be used to access them.
#define ca_field_type(CHID) ((CHID)->type)
#define ca_element_count(CHID) ((CHID)->count)
#define ca_name(CHID) ((char *)((CHID)+1))
#define ca_puser(CHID) ((CHID)->puser)
#define ca_host_name(CHID) ca_host_name_function(CHID)
#define ca_read_access(CHID) ((CHID)->ar.read_access)
#define ca_write_access(CHID) ((CHID)->ar.write_access)
* cs_ - `channel state'
* cs_never_conn valid chid, IOC not found
* cs_prev_conn valid chid, IOC was found, but unavailable
* cs_conn valid chid, IOC was found, still available
* cs_closed invalid chid
enum channel_state{cs_never_conn, cs_prev_conn, cs_conn, cs_closed};
#define ca_state(CHID) ((CHID)->state)
typedef struct ca_access_rights{
unsigned read_access:1;
unsigned write_access:1;
}caar;
/* Format for the arguments to user connection handlers */
struct connection_handler_args{
struct channel_in_use *chid; /* Channel id */
long op; /* External codes for CA op */
#ifdef CAC_FUNC_PROTO
typedef void caCh(struct connection_handler_args args);
#else /*CAC_FUNC_PROTO*/
typedef void caCh();
#endif /*CAC_FUNC_PROTO*/
/* Format for the arguments to user access rights handlers */
struct access_rights_handler_args{
caar ar; /* New access rights state */
typedef void caArh(struct access_rights_handler_args args);
typedef void caArh();
struct channel_in_use{
ELLNODE node; /* list ptrs */
short type; /* database field type */
#define TYPENOTCONN (-1) /* the type when disconnected */
unsigned short count; /* array element count */
union{
unsigned sid; /* server id */
struct db_addr *paddr; /* database address */
} id;
void *puser; /* user available area */
enum channel_state state; /* connected/ disconnected etc */
caar ar; /* access rights */
* The following fields may change or even vanish in the future
caCh *pConnFunc;
caArh *pAccessRightsFunc;
ELLLIST eventq;
unsigned cid; /* client id */
unsigned retry; /* search retry number */
void *piiu; /* private ioc in use block */
#ifdef vxWorks
void *ppn; /* ptr to optional put notify blk */
#endif /* vxWorks */
* channel name stored directly after this structure in a
* null terminated string.
typedef struct channel_in_use *chid;
typedef long chtype;
typedef struct pending_event *evid;
typedef double ca_real;
/* The conversion routine to call for each type */
#define VALID_TYPE(TYPE) (((unsigned short)TYPE)<=LAST_BUFFER_TYPE)
/* argument passed to event handlers and callback handlers */
long type; /* the type of the value returned */
struct pending_event{
void (*usr_func)(struct event_handler_args args);
void (*usr_func)();
void *usr_arg;
struct channel_in_use *chan;
chtype type; /* requested type for local CA */
unsigned long count; /* requested count for local CA */
* the following provide for reissuing a
* disconnected monitor
ca_real p_delta;
ca_real n_delta;
ca_real timeout;
unsigned id;
unsigned short mask;
void epicsShareAPI ca_test_event
/* Format for the arguments to user exception handlers */
struct exception_handler_args{
long type; /* Requested type for the operation */
long count; /* Requested count for the operation */
void *addr; /* User's address to write results of CA_OP_GET */
long stat; /* Channel access std status code */
long op; /* External codes for channel access operations */
char *ctx; /* A character string containing context info */
* External OP codes for CA operations
#define CA_OP_GET 0
#define CA_OP_PUT 1
#define CA_OP_SEARCH 2
#define CA_OP_ADD_EVENT 3
#define CA_OP_CLEAR_EVENT 4
#define CA_OP_OTHER 5
#define CA_OP_CONN_UP 6
#define CA_OP_CONN_DOWN 7
/* Perform Library Initialization */
/* Must be called once before calling any of the other routines */
int epicsShareAPI ca_task_initialize
void
/* Remove CA facility from your task */
/* Normally called automatically at task exit */
int epicsShareAPI ca_task_exit
void
/* Return a channel identification for the supplied channel name */
/* (and attempt to create a virtual circuit) */
* preferred search mechanism
#define ca_search(NAME,CHIDPTR)\
ca_search_and_connect(NAME, CHIDPTR, 0, 0)
/* ca_search
Name IO Value
char *, NAME R NULL term ASCII channel name string
chid * CHIDPTR RW channel index written here
* anachronistic entry points *
* **** Fetching a value while searching nolonger supported**** *
#define ca_build_channel(NAME,XXXXX,CHIDPTR,YYYYY)\
ca_build_and_connect(NAME, XXXXX, 1, CHIDPTR, YYYYY, 0, 0)
#define ca_array_build(NAME,XXXXX, ZZZZZZ, CHIDPTR,YYYYY)\
ca_build_and_connect(NAME, XXXXX, ZZZZZZ, CHIDPTR, YYYYY, 0, 0)
int epicsShareAPI ca_search_and_connect
/* Name IO Value */
char *,/* NAME R NULL term ASCII channel name string */
chid *,/* CHIDPTR RW channel index written here */
void (*)(struct connection_handler_args),
/* PFUNC R the address of user's connection handler*/
void * /* PUSER R placed in the channel's puser field */
* anachronistic entry point *
int epicsShareAPI ca_build_and_connect
/* Name IO Value */
char *, /* NAME R NULL term ASCII channel name string */
chtype, /* GET_TYPE R external channel type to get */
unsigned/* (no get if invalid type) */
long, /* GET_COUNT R array count to get */
chid *, /* CHIDPTR RW channel index written here */
void *, /* PVALUE W A pointer to a user supplied buffer */
int epicsShareAPI ca_change_connection_event
chid chix,
void (*pfunc)(struct connection_handler_args)
int epicsShareAPI ca_replace_access_rights_event(
chid chix,
void (*pfunc)(struct access_rights_handler_args)
* replace the default exception handler
int epicsShareAPI ca_add_exception_event
void (*pfunc)(struct exception_handler_args),
void *arg
/* deallocate resources reserved for a channel */
int epicsShareAPI ca_clear_channel
/* Name IO Value */
chid /* CHAN, R channel identifier */
/* Write a value to a channel */
#define ca_bput(CHID,PVALUE) ca_array_put(DBR_STRING, 1, CHID, (PVALUE))
C Type Name IO Value
chid CHID R channel id
char * PVALUE R pointer to a binary value string
#define ca_rput(CHID,PVALUE)\
ca_array_put(DBR_FLOAT, 1, CHID, (PVALUE))
dbr_float_t * PVALUE R pointer to a real value
#define ca_put(CHTYPE, CHID, PVALUE) ca_array_put(CHTYPE, 1, CHID, PVALUE)
Name IO Value
chtype, TYPE R channel type
chid, CHID R channel index
void * PVALUE R pointer to new channel value of type specified
i.e. status = ca_put(DBF_INT,chid,&value)
int epicsShareAPI ca_array_put
/* Name IO Value */
chtype, /* TYPE R channel type */
unsigned long,
/* COUNT R array element count */
chid, /* CHID R channel index */
void * /* PVALUE R pointer to new channel value of type */
/* specified. */
* This routine functions identically to the original ca put request
* with the addition of a callback to the user supplied function
* after recod processing completes in the IOC. The arguments
* to the user supplied callback function are declared in
* the structure event_handler_args and include the pointer
* sized user argument supplied when ca_array_get_callback() is called.
int epicsShareAPI ca_array_put_callback
/* Name IO Value */
unsigned long,
void *, /* PVALUE R pointer to new channel value of type */
void (*)(struct event_handler_args),
/* USRFUNC R the address of a user supplied function */
void * /* USRARG R An argument copied to the above function*/
/* Read a value from a channel */
#define ca_bget(CHID,PVALUE) ca_array_get(DBR_STRING, 1, CHID, PVALUE)
char * PVALUE W string value pointer
#define ca_rget(CHID,PVALUE) ca_array_get(DBR_FLOAT, 1, CHID, PVALUE)
dbr_float_t * PVALUE W real value pointer
#define ca_get(CHTYPE, CHID, PVALUE) ca_array_get(CHTYPE, 1, CHID, PVALUE)
void * PVALUE W ptr to where channel value written
int epicsShareAPI ca_array_get
/* Name IO Value */
unsigned long,
void * /* PVALUE W ptr to where channel value written */
/* Read a value from a channel and run a callback when the value */
/* returns */
#define ca_bget_callback(CHID,PFUNC,ARG)\
ca_array_get_callback(DBR_STRING, 1, CHID, PFUNC, ARG)
void (*)(), PFUNC R the address of a user supplied function
void *, ARG R An argument copied to the above function
#define ca_rget_callback(CHID,PFUNC,ARG)\
ca_array_get_callback(DBR_FLOAT, 1, CHID, PFUNC, ARG)
#define ca_get_callback(CHTYPE, CHID,PFUNC,ARG)\
ca_array_get_callback(CHTYPE, 1, CHID, PFUNC, ARG)
int epicsShareAPI ca_array_get_callback
/* Name IO Value */
unsigned long,
void * /* USRARG R An argument copied to the above function */
/* Specify a function to be executed whenever significant changes */
/* occur to a channel. */
/* NOTES: */
/* 1) Evid may be omited by passing a NULL pointer */
/* 2) AN array count of zero specifies the native db count */
typedef struct event_handler_args evargs;
/* Assumes DELTA info comes from the database or defaults */
#define ca_add_event(TYPE,CHID,ENTRY,ARG,EVID)\
ca_add_array_event(TYPE,1,CHID,ENTRY,ARG,0.0,0.0,0.0,EVID)
/* Name IO Value
void
(*)(), USRFUNC R the address of a user supplied function
void *, USRARG R An argument copied to the above function
evid * EVIDPTR W An id to refer to this event by
/* Sets both P_DELTA and M_DELTA below to argument DELTA */
#define ca_add_delta_event(TYPE,CHID,ENTRY,ARG,DELTA,EVID)\
ca_add_array_event(TYPE,1,CHID,ENTRY,ARG,DELTA,DELTA,0.0,EVID)
/* Name IO Value
void
ca_real, DELTA R Generate events after +-delta excursions
#define ca_add_general_event(TYPE,CHID,ENTRY,ARG,P_DELTA,N_DELTA,TO,EVID)\
ca_add_array_event(TYPE,1,CHID,ENTRY,ARG,P_DELTA,N_DELTA,TO,EVID)
#define ca_add_array_event(TYPE,COUNT,CHID,ENTRY,ARG,P_DELTA,N_DELTA,TO,EVID)\
ca_add_masked_array_event(TYPE,COUNT,CHID,ENTRY,ARG,P_DELTA,N_DELTA,TO,EVID, DBE_VALUE | DBE_ALARM)
int epicsShareAPI ca_add_masked_array_event
/* Name IO Value */
chtype, /* TYPE R requested external channel type */
unsigned long,
void *, /* USRARG R An argument copied to the above function*/
ca_real,/* P_DELTA R Generate events after +delta excursions */
ca_real,/* N_DELTA R Generate events after -delta excursions */
ca_real,/* TIMEOUT R Generate events after timeout sec */
evid *, /* EVIDPTR W An id to refer to this event by */
long /* MASK R event trigger type */
/* Remove a function from a list of those specified to run */
/* whenever significant changes occur to a channel */
int epicsShareAPI ca_clear_event
/* Name IO Value */
evid /* EVID R Event id returned by add event */
/* Requested data is not necessarily stable prior to */
/* return from called subroutine. Call ca_pend_io() */
/* to guarantee that requested data is stable. Call the routine */
/* ca_flush_io() to force all outstanding subroutine calls to be */
/* sent out over the network. Significant increases in */
/* performance have been measured when batching several remote */
/* subroutine calls together into one message. Additional */
/* improvements can be obtained by performing local processing */
/* in parallel with outstanding remote processing. */
/* FLOW OF TYPICAL APPLICATION */
/* search() ! Obtain Channel ids */
/* get() ! several requests for remote info */
/* get() ! " */
/* add_event() ! " */
/* get() ! " */
/* flush_io() ! send get requests */
/* ! optional parallel processing */
/* pend_io() ! wait for replies from get requests */
/* . ! access to requested data */
/* pend_event() ! wait for requested events */
/* This routine pends waiting for channel events and calls the */
/* functions specified with add_event when events occur. If the */
/* timeout is specified as 0 an infinite timeout is assumed. */
/* if the argument early is specified TRUE then CA_NORMAL is */
/* returned when outstanding queries complete. Otherwise if the */
/* argument early is FALSE the routine does not return until the */
/* entire delay specified by the timeout argument has expired. */
/* ca_flush_io() is called by this routine. If the argument */
/* early is TRUE then ca_pend() will return immediately without */
/* processing outstanding CA labor if no queries are outstanding */
#define ca_pend_event(TIMEOUT) ca_pend((TIMEOUT), 0/*FALSE*/)
#define ca_pend_io(TIMEOUT) ca_pend((TIMEOUT), 1/*TRUE*/)
int epicsShareAPI ca_pend
/* Name IO Value */
ca_real,/* TIMEOUT R timeout in seconds */
int /* EARLY R return early if IO completes */
* returns TRUE when queries are outstanding
int epicsShareAPI ca_test_io
/* Name IO Value */
void
/* Send out all outstanding messages in the send queue */
int epicsShareAPI ca_flush_io
void
void epicsShareAPI ca_signal
/* Name IO Value */
long, /* CODE R status returned from channel access function */
char * /* MSG R null term string printed on error */
void epicsShareAPI ca_signal_with_file_and_lineno
/* Name IO Value */
char *, /* MSG R null term string printed on error */
char *, /* FILE R pointer to null terminated file name string */
int /* LINENO R line number */
* Provided for efficient test and display of channel access errors
#define SEVCHK(CA_ERROR_CODE, MESSAGE_STRING) \
int ca_unique_status_name = (CA_ERROR_CODE); \
if(!(ca_unique_status_name & CA_M_SUCCESS)) \
ca_signal_with_file_and_lineno( \
ca_unique_status_name, \
(MESSAGE_STRING), \
__FILE__, \
__LINE__); \
char * epicsShareAPI ca_host_name_function
/* Name IO Value */
chid /* CHID R Channel ID */
* CA_ADD_FD_REGISTRATION
* call their function with their argument whenever
* a new fd is added or removed
* (for use with a manager of the select system call under UNIX)
typedef void CAFDHANDLER(void *parg, int fd, int opened);
typedef void CAFDHANDLER();
int epicsShareAPI ca_add_fd_registration(
CAFDHANDLER *pHandler,
void *pArg
#ifdef vxWorks
int epicsShareAPI ca_channel_status(
int tid
#endif
#ifdef vxWorks
int ca_import(int tid);
int ca_import();
#ifdef vxWorks
int ca_import_cancel(int tid);
int ca_import_cancel();
* CA synch groups
* This facility will allow the programmer to create
* any number of synchronization groups. The programmer might then
* interleave IO requests within any of the groups. Once The
* IO operations are initiated then the programmer is free to
* block for IO completion within any one of the groups as needed.
typedef unsigned WRITEABLE_CA_SYNC_GID;
typedef const unsigned CA_SYNC_GID;
#else
typedef unsigned CA_SYNC_GID;
#endif
* create a sync group
int epicsShareAPI ca_sg_create(
CA_SYNC_GID *pgid
* delete a sync group
int epicsShareAPI ca_sg_delete(
CA_SYNC_GID gid
* block for IO performed within a sync group to complete
int epicsShareAPI ca_sg_block(
CA_SYNC_GID gid,
ca_real timeout
* test for sync group IO operations in progress
int epicsShareAPI ca_sg_test(
CA_SYNC_GID gid
* ca_sg_reset
int epicsShareAPI ca_sg_reset(
CA_SYNC_GID gid
* initiate a get within a sync group
* (essentially a ca_array_get() with a sync group specified)
int epicsShareAPI ca_sg_array_get
/* Name IO Value */
CA_SYNC_GID,/* GID R synch group id */
unsigned long,
* initiate a put within a sync group
* (essentially a ca_array_put() with a sync group specified)
int epicsShareAPI ca_sg_array_put
/* Name IO Value */
unsigned long,
/* specified. */
* CA_MODIFY_USER_NAME()
* Modify or override the default
* client user name.
int epicsShareAPI ca_modify_user_name(char *pUserName);
int epicsShareAPI ca_modify_user_name();
* CA_MODIFY_HOST_NAME()
* client host name.
int epicsShareAPI ca_modify_host_name(char *pHostName);
int epicsShareAPI ca_modify_host_name();
* Put call back is available if the CA server is on version is 4.2
* or higher.
* (return true or false)
int epicsShareAPI ca_v42_ok(chid chan);
int epicsShareAPI ca_v42_ok();
* ca_replace_printf_handler ()
* for apps that want to change where ca formatted
* text output goes
int epicsShareAPI ca_replace_printf_handler (
int (*ca_printf_func)(const char *pformat, va_list args)
int epicsShareAPI ca_replace_printf_handler ();
#ifdef __cplusplus
#endif
* no additions below this endif
#endif /* INCLcadefh */
What th??? (was: Re: Epics C++ Problems) John R. Winans
EPICS RS232 Ian Smith
<1995>
2025
Re: Epics C++ Problems John R. Winans
Re: Epics C++ Problems Jeff Hill
<1995>
2025
