1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Subroutine record input fields don't get archived
To: [email protected]
Cc: [email protected], [email protected]
Date: Tue, 24 Oct 95 07:38:57 MDT
> From [email protected] Tue Oct 24 03:45:03 1995
> Return-Path: <[email protected]>
> Date: Tue, 24 Oct 1995 10:48:12 +0100 (BST)
> Subject: more help with ar, please
> Mime-Version: 1.0
> Content-Type> : > TEXT/PLAIN> ; > charset=US-ASCII>
> Content-Length: 1374
> X-Lines: 53
> I just started to cool a cryostat with epics reading the temperatures and
> AR logging them.  I just happened to notice that the values written to
> disk were repititions of the initial temperatures, not what epics was
> currently reading, ie:
> PROGRAM: AR
> SAMPLE: at 10/24/95 10:39:16.020--operator snapshot
> %endHeader%
> ser3:ecalcs_54.VAL DBF_DOUBLE 0 0 1 8203.000
> ser3:emosub_87.VALA DBF_DOUBLE 0 0 1 261.8000000
> ser3:emosub_87.VALC DBF_DOUBLE 0 0 1 280.8000000
> %endData%
> PROGRAM: AR
> SAMPLE: at 10/24/95 10:40:56.020--operator snapshot
> %endHeader%
> ser3:ecalcs_54.VAL DBF_DOUBLE 0 0 1 8303.000
> %endData%
> the temperatures are actually changing, I can see them on a dm display
> which is connected to exactly the same records/fields.
> My archive script is:
> DESC: test it
> ACT: always
> INACT: never
> TRIGGER: every 0:1:40
> SNAPSHOT: for 1 samples
> OUTPUT: set:txt /net/idsun1/epics1/mch/epics/ar/arSet/ls2.txt
> %endHeader%
> ser3:ecalcs_54.VAL
> F ser3:emosub_87.VALA
> # F ser3:emosub_87.VALB
> F ser3:emosub_87.VALC
> F ser3:emosub_87.VALD
> F ser3:emosub_87.VALF
> F ser3:emosub_44.VALA
> Dose anybody have any ideas?
> tia
> Ian A Smith
> Telephone:
> +44 (0) 131 668 8257 Royal Observatory		Fax:       +44 (0) 131 668 1130
> Blackford Hill			Web:       http://www.roe.ac.uk/
> Edinburgh
> UK
What kind of a record is emosub_87?
If it is a subroutine record it looks from the
subroutine record code that the archiver will not get any values back
but the val field.
I am going to post this reply to the exploder also,
so that someone who is an expert on record code can also reply.
I am appending the relevant segment of code from the record support
for subroutine records to this message.
The code could be changed so that archive values would be
returned for the subroutine input fields by checking the difference
between *pnew and *pprev against psub->adel in the loop that posts monitors
for changes in the input fields and setting the bit for DBE_LOG in the monitor
mask in case the change is larger than psub->adel.  The problem with
this approach is that there is only one adel and it will probably not
fit all the input fields.
 /* check for archive change */
        delta = psub->alst - psub->val;
        if(delta<0.0) delta = -delta;
        if (delta > psub->adel) {
                /* post events on value field for archive change */
                monitor_mask |= DBE_LOG;
                /* update last archive value monitored */
                psub->alst = psub->val;
        /* send out monitors connected to the value field */
        if (monitor_mask){
                db_post_events(psub,&psub->val,monitor_mask);
	/* check all input fields for changes*/
	for(i=0, pnew=&psub->a, pprev=&psub->la; i<ARG_MAX; i++, pnew++, pprev++) {
		if(*pnew != *pprev) {
			db_post_events(psub,pnew,monitor_mask|DBE_VALUE);
			*pprev = *pnew;
        return;
Rozelle Wright
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs AOT-8  FAX (505) 665-5107         |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
Re: Subroutine record input fields don't get archived I.Smith
Prev: more help with ar, please Ian Smith
Next: Re: Subroutine record input fields don't get archived Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Subroutine record input fields don't get archived I.Smith
