1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CAN connection
To: [email protected]
Cc: [email protected] (Gabor Csuka)
Date: Thu, 02 Nov 1995 11:22:29 +0100 (MET)
> >The CAN bus now successfully connected to Epics (R3.12.1),
> >useing CDI V4.0 interface.
> For anyone who doesn't want to use the CDI, I wrote an EPICS CANbus driver which is
> already in use on UKIRT (and will be used by Gemini).  This drives the TIP810 IP
> module and has been tested using the Greenspring VIPC310 and VIPC610 carrier boards
> but also has software to drive the mv162 (not tested).  Device support is provided
> for ai, ao, bi, bo, mbbi, mbbo, mbbiDirect and mbboDirect records with full I/O
> interrupt and asynchronous record processing.  You can even use EPICS to build a
> simulator for another CANbus device to respond to RTRs on the bus.
> Documentation is in preparation, and should be available shortly.
> - Andrew
>   O o ._    Andrew Johnson, Royal Greenwich Observatory
>      __\\_	Madingley Road, Cambridge, CB3 0EZ
>   __|ooooo|__	Tel +44 (0)1223 374823  Fax 374700
> ~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
I will be very glad to test Andrew's CAN driver and epics connection on our
environment while we have the TIP810 IP module, maybe this is bettert implemented
with more funcionality then ours.
- regards,
Gabor
DESY, Germany
Re: CAN connection Andrew Johnson
Prev: Has anyone integrated the Heurikon "NITRO 60" Bill Brown
Next: Re: Has anyone integrated the Heurikon "Nitro 60" 415
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CAN connection Andrew Johnson
Next: Re: Subroutine Records Gordon Uchenick
