1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: AR in server mode and cmdClient
To: [email protected]
Date: Wed, 8 Nov 95 10:29:45 HST
Dear all,
Peregrine wrote:
> cmdClient is in base at $EPICS/base/src/util/cmdClient.c and the
> executable should be in $EPICS/base/bin/<arch>.
Deb Wrote:
> Perry indicated where to find it.  My version of 3.12 indicates that
> base/src/util/cmdClient.c was put in the cvs Attic at some point.
> If you can't find it in your release of EPICS, it's probably retrievable
> there somewhere.  I'm not sure if we should get it set up in extensions/ar
> or what.
I assume that most of the stuff from base/src/util was moved to
extensions/ar/syd? Apparently cmdClient.c was omitted?
Anyway, as a stopgap, I have moved cmdClient.c (I had it in the Attic
from Beta1) there too and butchered the Makefile to build it (it
introduces a cross-dependence between ar/syd and ar/ar which needs
fixing since cmdClient needs ezsSockSubr which is in ar/ar...).
Thanks for your help,
William
Prev: Re: AR in server mode and cmdClient Deb Kerstiens
Next: Re: AR in server mode and cmdClient Jeff Hill
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
