1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: iocInit hangs connecting to the log server
To: [email protected]
Date: Wed, 8 Nov 95 17:21:38 MST
Hello All,
Recently a subtle problem related to the IOCs reconnecting to the
log server has been fixed.
Symptoms:
o Long hang connecting to the log server in iocInit.
Cause(s):
o I followed normal convention and allowed the local port number
	for the log client to be assigned by vxWorks
o The log client's local port number is always assigned to be the
	same number (1044) when the IOC reboots
o SUNOS4 becomes confused when the IOC begins sending TCP SYNC messages
	from a port that it has been serving before the IOC rebooted
o SUNOS4 does not send a TCP FINISH to the IOC even if the TCP/IP sequence
	numbers are obviously wrong.
o vxWorks does not send a TCP FINISH when the user types ^X
Solution:
o Transparently reconnect to the log server several times in order to
	guarantee that we dont start out on a port number that is in use
	when the IOC reboots.
The necessary changes have been checked in at APS. I dont know if this
will end up in 3.12.2.
I have also fixed the log client so that it will reconnect to the log
server if the log server is restarted (as suggested by LBL).
It is interesting that this problem does not appear to show up when
CA clients are rebooted (and they must reattach to CA servers running
under vxWorks). I assume that this results from a slightly different
implementation of TCP/IP under vxWorks. I will look into this in greater
detail when more urgent matters have been resolved (ie list of priorities
arrived at at the last collaboration meeting).
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: Re: AR in server mode and cmdClient Rozelle Wright
Next: epicsPrint: semTake returned error Paul Banta
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
