1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Burt and km under Solaris
Cc: [email protected]
Date: Fri, 16 Feb 1996 16:11:18 -0600
>Probably too dumb actually - this makes sense under Solaris where /usr/ucb/cc
>aborts with exit status 1, because the compiler isn't bundled.  I provided
>binaries to J.F. Gournay, so he probably doesn't have SUNWspro.  However, the CPP
>in /usr/ccs/lib should work, so the simple answer is probably to create a symbolic
>link to it named cc in some BURT-searched directory (will this work?).
It will if it can deal with the flags that burt sends to what it thinks
is called 'cc' you might have to write a shell named cc that strips off
the -E flag.
>>I have no idea why this is so... It makes no sense to me.
>It does if you realise that the binaries he is using were copied from APS's
>/usr/local/epics/extensions/bin/solaris directory, where they were compiled
>against X11R5 rather than openwin.  I can't build BURT here because it won't
>compile using g++.
The new one should compile with gcc.  However, I still have zero clue
why burtrb needs anything from X... the gooey thing obviously needs X
stuff, but the command line stuff sure shouldn't.
--John Winans
Re: Burt and km under Solaris Andrew Johnson
Prev: Field type Andy Kozubal
Next: Re: Field type Jeff Hill
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Burt and km under Solaris Andrew Johnson
Next: Re: Burt and km under Solaris J.F. Gournay
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
