1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Access Security
To: [email protected], [email protected]
Date: Thu, 22 Feb 96 10:53:34 MST
Stephanie writes:
> And another opinion -
> The MEDM way is good though I would add an explanation of what it
> means to an easily accessible "help" display.
> If the decision is to go with some sort of color coding, please
> please please let the color be configurable!  I was dismayed that
> the color chosen for when a color rule cannot be resolved is white
> and not configurable (on our system, magenta would be a better color
> leaving white to mean channel-cannot-be-connected though it would
> also be nice if the channel-not-connected color is configurable too,
> sigh).
The color model for edd/dm is currently based upon using colors that are in
the "color map" for the display (or the external color palette.)  These
colors are specified using RGB values, not the "named color" model. Although
it is quite possible to allow color configurations as args, resources,
etc., I'd prefer not to do so.  Would it be sufficient to add a field to
the color rule configuration to allow selection of a color in the case that
color rules could not be resolved(just as one can select default fg and bg)?
In a similar fashion, what about allowing fg and bg color selection for
"not connected" to be available as part of the "modify display attributes"?
Deb
Prev: Re: "dm" and Access Security Jeff Hill
Next: Re: EPICS Access Security Andrew Johnson
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Access Security Jeff Hill
