1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Access Security
To: [email protected]
Date: Thu, 22 Feb 1996 17:56:10 +0000 (GMT)
On Thu, 22 Feb 96 several people responded to my suggestion:
>> >IMHO there should be a way of being able to put _something_ on a display which
>> >tells you without having to move a mouse whether you have write access to a
>> >system.
If Deb can somehow incorporate access security into the edd/dm colour rules,
display screen designers can do whatever they like:
  * Coloured bounding box?  Put a filled rectangle behind the control with
    a rule controlling the rectangle colour.
  * Dashed?  Make the rectangle un-filled and dashed.
  * A cross over the top?  Do something similar with lines.
  * Controller itself should change colour?  Easy.
  * Text to tell you about your rights? ...
  * No indication other than mouse cursor?  Don't use A.S. in the colour rule.
This then becomes a tool rather than an enforced method which some people might
disagree with.
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_      Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__   Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Prev: Re: EPICS Access Security Deb Kerstiens
Next: Re: "dm" and Access Security Marty Kraimer
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS Access Security 415
