1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "dm" and Access Security
To: [email protected]
Date: Thu, 22 Feb 1996 12:42:32 -0600
Jeff Hill wrote:
> > Another requirement of the Gemini Project is to be
> > able to dynamically change access to various records and
> > fields. If my understanding is correct, you can do this by
> > calling a special routine from a SUB record which re-initialises
> > access security by re-reading the ACF.
> or just modify a PV that provides input to the access security rules
> Jeff
What Jeff suggests is the best way to satisfy this requirement.
The alternative of rereading the access config file is a rather
drastic measurre. It is really meant for the case in which access
rules are acutally changed without requiring ioc reboots. It
has much more overhead than what Jeff suggests.
As regards to dm (medm). Channel Access supplys a change
of access state callback. CA tools should use this callbacxk.
I know that medm uses it properly, i.e. access icons change
as access priviledge changes.
Marty Kraimer
Re: "dm" and Access Security Jeff Hill
Prev: Re: EPICS Access Security Andrew Johnson
Next: Re: EPICS Access Security 415
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "dm" and Access Security Jeff Hill
Next: Omissions in 3.12.2 Bill Brown
