1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dm display arguments declaration
To: [email protected]
Cc: [email protected]
Date: Fri, 23 Feb 96 13:38:14 MST
Andrew,
> From: Andrew Johnson <[email protected]>
> looks good.
> On Fri, 23 Feb 96 11:46:18 MST Jeff Hill <[email protected]> wrote:
> >If they dont specify "BLDG" then they will be prompted for this
> >argument via a dialog box.
> It would be friendly if you somehow allowed the display designer to specify an
> optional prompt string for the dialog box for each prompted argument.  That way
> the argument name can be hidden if the designer wishes.
agree. we should modify the syntax as follows?
"BPMNO <beam position monitor number> = 1, SECTOR = blue, BLDG <building>"
where the <> immediately following the macro name will specify the optional
prompt string?
Jeff
Prev: Re: dm display arguments declaration William Lupton
Next: dm Ric Claus
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: dm Ric Claus
