1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: dm
To: [email protected]
Cc: [email protected]
Date: Fri, 23 Feb 1996 13:18:42 -0800 (PST)
As long as we're talking about changes to dm, here are some suggestions that
I would like to see implemented.
I would really like to be able to enter hex numbers into a "text entry" object
for things that require numbers but I don't see any way to do it.  Could dm
be modified to interpret numbers with a leading "0x", "0X" or trailing "x" or
"X" as hexadecimal numbers?  I include the last two choices only to be
consistent with the way dm displays hex numbers with "text update" objects.
I find that in some cases undesired behavior is produced when continuously
updating the .VAL field with a changing valuator.  I realize that this behavior
can be changed with the menu on the live valuator, but I would rather like to
be able to set the defaults in this menu with edd when the valuator is created
or modified.
	Ric
Prev: Re: dm display arguments declaration Jeff Hill
Next: Re: dm Deb Kerstiens
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
