1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Illegal Lock Set Lock Set out of range:dbScanLock
To: [email protected]
Date: Tue, 12 Mar 1996 08:06:09 -0600
Gabor Csuka wrote:
> Hi,
> In EpiX R3.12.2 (+ DESY update) I have founded:
> H1_1 efaea0 0
> task: 0Xce682c callback
> task: 0Xcf7f4c taskwd
> task ce682c callback suspended
> Any idea ?
> Regards:
> Gabor Csuka
> DESY, Germany
One of two things probably happened.
1) iocInit did not complete. Check this first by carefully looking at
   messages displayed on vxWorks console while iocInit is executing.
2) Something wrote to illegal part of memory including the LSET
   field of a record. This happens for one of two reasons:
  a) Bad record/device support. Common problem when developing new
  b) The record/device support was compiled against a different version
       of epics than default.dctsdr. This happens if fields in record
      are changed between epics versions. Perform a gnumake clean
     and then rebuild local record/device/driver support.
If you dont have quick success try removing all record instances that
use locally written record/device/driver support and slowly add it
back until problem can be isolated to particular record/device support.
Marty Kraimer
Illegal Lock Set Lock Set out of range:dbScanLock Gabor Csuka
Prev: Illegal Lock Set Lock Set out of range:dbScanLock Gabor Csuka
Next: vxWorks stat through EPICS records Jim B. Kowalkowski
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
