Everyone,
I've put together ai/ao device support that efficiently gives access to the
following vxWorks statistics:
ai:
free_bytes - number of bytes in IOC not allocated
allocated_bytes - number of bytes allocated
load - estimated percent CPU usage by tasks
tcp_connections - number of TCP connection currently in use
ao:
memoryScanRate - max rate at which new memory stats can be read
tcpScanRate - max rate at which TCP connections can be calculated
loadScanRate - max rate at which load can be calulated
loadSampleRate - vxWorks spy facility samples-per-second for load
loadSampleLength - length of time in second that samples for load
calculation are taken.
Get the source code from the APS ftp server:
epics.aps.anl.gov:pub/epics/extensions/devAiStats.c
A sample database and doc are included as a comment in the source code
along with the devSup.ascii modifications needed.
Jim
Re: Illegal Lock Set Lock Set out of range:dbScanLock Marty Kraimer
Channel access security Frank Lenkszus
<1996>
2025
<1996>
2025
