1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Channel access security
To: [email protected]
Date: Tue, 12 Mar 1996 15:18:23 -0600
I've come across a situation in which I have 20 iocs, each of which will have
a unique access security group with access conditioned on a local process
variable. The form of the 20 access security rules is the same. I have 2 choices
for handling this. Create 20 unique files each with a single access group, or
create 1 file that includes all 20 access groups. The first option's
disadvantage is it requires 20 files. The second's disadvantage is that each
ioc will create a channel access connection to the 19 pv's that are not local
even though the rules invoking those pvs are never used in the that ioc.
Not a pleasant thought. In this case, I'd get 19x20 or 380 superfluous channel
access connections. Sooo, for now, I'll just create a template and use subtool
it create 20 access security files.
It would have been real handy though, if asSetFilename supported macro
substitution. If that were so, I could defer macro substitution to the
start up command files.  Anyway, I suggest that some future incarnation of
asSetFilename support macro substitution.  Comments?
Frank
Prev: vxWorks stat through EPICS records Jim B. Kowalkowski
Next: Bug in OMS Driver routines Guy Jennings
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
