1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: rewrite of et_wish
To: [email protected]
Date: Wed, 17 Apr 96 16:13:10 HST
----- Begin Included Message -----
>From wlupton Wed Apr 17 15:56:07 1996
Status: O
Claude,
> I am currently reviewing and reworking the et_wish library (the
> channel access extension to tcl/tk). It will be renamed tclCa...
Sounds good. I have a few suggestions (the first is specific to a problem
that I had in my _very_ limited use of et):
1. In a simple example, I found that a monitor, although it changed the
   specified Tcl variable, did not automatically update a label that
   referenced it via -textvariable. I had to do something like {set v
   $v} in the monitor callback in order to get this to work.
2. It would be good to maximize support for event-driven applications
   (e.g.  as well as supporting connection state change callbacks,
   support get and put completion callbacks rather than having to use
   "pv stat" to poll for completion).
3. What about passing automatic extra arguments to callback routines,
   e.g. the name of the linked Tcl variable, an error code (rather than
   having to use the global errorCode), ... (or specify a different
   routine to call in the event of error?)? This might make it neater to
   write generic callback routines, and should be upwards compatible.
William
----- End Included Message -----
Prev: gdct Ric Claus
Next: Sequencer time string T.A.Coleman, ANL ECT 222
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: rewrite of et_wish Claude Saunders
Next: gdct Ric Claus
