1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: A bad thing happens when I build base/
To: [email protected]
Date: Tue, 30 Apr 96 11:18:06 PDT
We've been having a problem for some time (I _think_ we had it in 3.12.1 also)
that's been shoving us "'round the bend", so to speak.  OK - so maybe all
it takes is a gentle push.  But I digress.
When we do a co of epics from our repository, everything looks fine.  However
after we do the initial gmake from base/ the sub-directory base/rec/CVS and
all its contents are GONE!  This makes bad things happen when one tries to
do a "cvs commit" or "cvs update."
AFAIK I haven't touched the Makefiles in this area, and except for the
base/rec/CVS directory all else is as one would expect.  Nothing else seems
to be getting stepped-on.
Has anyone else ever seen this?  Can someone give me a clue?  It's
reproduceable in our environment, which is really pretty vanilla, I
think.
It took me a while to figure out what was happening - by the time I'd noticed
we had a problem I'd done enough other stuff to where I thought I must have
done it, but in this test case I checked out the tree and the mentioned sub-
directory was there.  After I did gmake from base/, it was gone.
Still clueless in Berkeley.....
-bill
Prev: Event Scanned Records - Multiple Priorities Marty Kraimer
Next: VXI support Ric Claus
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: A bad thing happens when I build base/ Andrew Johnson
