1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: VXI support
To: [email protected]
Cc: [email protected]
Date: Tue, 30 Apr 1996 12:37:08 -0700
VXI gurus,
  I'm starting to develop driver and device support for a bunch of in-house VXI
modules.  These are register based modules which occupy space in both A16 and A24
space.  Some of them have DSPs on them which will need to be loaded with code and
coefficient tables.  I've been using drvAt5Vxi.c as a model.  My VXI slot 0
processor is a National Instruments VXIcpu-030.  There is no MXI in the system.
I'm using EPICS 3.12.2.
  First off, are there any new developments that I should be aware of?  Second,
documentation for VXI support seems to be rather scarce, with only Jeff Hill's
man pages to go on.  Is there any other documentation around?  There seems to
be a lot of stuff #if'ed out in the code, so I'm wondering if this is a finished
product.
  SLAC does not appear to have a VXI manufacturer ID and so the boards are being
loaded with code 0xf00 which is defined as "user custom".  Will EPICS VXI support
work with this?  Does it care?
  There is a non-VXI device in the crate (an Allen Bradley 6008-SV1R Scanner
module) on an HP E1407A VME-VXI adapter.  How do I tell the EPICS resource
manager about it?  Does it care?
  drvAt5Vxi seems to require drvEpvxi (which I guess replaces epvxiLib?).  It
also requires the resource manager to have run before its init routine will
complete.  How is this guaranteed?
Thanks.
	Ric Claus	([email protected], (415) 926-2697)
Re: VXI support Jeff Hill
Prev: A bad thing happens when I build base/ Bill Brown
Next: Re: A bad thing happens when I build base/ Andrew Johnson
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: A bad thing happens when I build base/ Bill Brown
Next: Re: VXI support Jeff Hill
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
