1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MC 68060 FP Math Performance
To: [email protected]
Date: Thu, 30 May 1996 09:08:01 -0600
the vxWorks Users Group Exploder wrote:
> > We are using an MVE177 with 68060 CPU and seeing greatly degraded FP
> > performance when dealing with numbers whose magnitude are less than
> > FLT_MIN.  This can cause a fabs() call to go from 1 microsec to 53
> > microsec!  Similar degradation occurs for all FP Math operations.
> > Has anyone else seen this and can suggest a workaround.  This is of
> > great concern to us in a high speed (1KHz) application which is math
> > intensive.
> Yes, you are getting underflow exception errors.  You'll have to figure
> out how to turn that off.  This is a problem on 167 boards as well.
> We had first noticed this when comparing performance of applications
> running single-precision vs. double-precision calculations.  We were
> surprised to see that the single-precision version ran slower.
> The reason was that it (a simulated controls system) was doing such a
> good job that the errors in the system were below FLT_MIN, thereby
> generating underflow exceptions.  It took the double-precision
> application much longer to hit its underflow limit, so it ran faster
> before that point.
> We "fixed" the problem by injection noise on the order of FLT_MIN into
> the system, since we couldn't disable exception-handling for
> underflow.
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: Re: CA questions Jeff Hill
Next: EPICS PostScript Documents Roland Mueller
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Burt compile. MURANAKA Masaki
