1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Performance Comparison for mv167 and mv177
To: [email protected]
Cc: [email protected]
Date: Mon, 24 Jun 96 12:43:31 EDT
This mail is made of the recycled electrons
Mailer: Elm [revision: 70.85]
Results on Performance Measurements on mv167 (33MHZ) and mv177(50MHZ)
I. EPICS Database for IOC Performance Measurement
   The testing epics database was designed by Marty Kraimer of
APS. In the database, there is one master fanout record which
forwards another 6 fanout records. Each of these six fanout
records forwards to 5 calculation records. Each of these five
calc record forwards to a chain of 9 ai records as shown in
the following diagram.
   Mfanout -> Sfanout1 ---> calc1 --> ai1 -> ai2 -> ... -> ai9
           -> Sfanout2   -> calc2
             .           -> calc5
           -> Sfanout6
II. Procedure of Measurements
   i. Step through the scan field of Mfanout:
      1sec, .5sec, .2sec and .1sec
   ii. For each of above scan rates,
       start spy;
       wait until cpu usage of the scanPeriod Task stablized;
       record cpu usage of the scanPeriod Task and cpu idle;
       stop the spy;
III. Results -- R3.12.2 epics
        mv167(33MHZ)              mv177(50MHZ)              mv177(50MHZ)
                                  with 68040 epics          with 68060 epics*
       scanPeriod    CPU IDL      scanPeriod    CPU IDL     scanPeriod    CPU IDL
       CPU usage                  CPU usage                 CPU usage
1  sec     2%          90%            1%           90%          1%          90%
.5 sec     6%          84%            2%           89%          2%          90%
.2 sec    14%          56%            7%           79%          7%          80%
.1 sec    29%          35%           13%           66%         13%          66%
        (event lost)
* epics base compiled with -DCPU=MC68060 which affects the vxWorks kernel
VI. Conclusions
    1. For about 300 epics records, mv177(50Mhz) is 2 times faster
       than mv167(33Mhz) at the epics records running 1Hz and 5Hz scan rates;
       About 2.5 times faster at the epics records running 10Hz;
       3 times faster at the epics records running 2Hz.
    2. The event lost happens when 300 epics records running at the
       scan rate 10Hz on mv167(33Mhz).
    3. The performances are almost identical between epics 68040 executable and
       epics 68060 executable running on mv177.
Johnny Tang     Voice: (804)249-7239  E-Mail: [email protected]
Continuous Electron Beam Accelerator Facility
12000 Jefferson Avenue, MS 85A
Newport News, Virginia 23606
Prev: What's the Password? Mark M . Ito
Next: Re: What's the Password? Bakul Banerjee
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: What's the Password? Bakul Banerjee
Next: Medm help Vladimir T. Romanovski
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
