Dear EPICS-ians,
I have asked a quesion about CAMAC serial driver used with EPICS. I got
several responces from
[email protected]
[email protected]
[email protected]
[email protected]
Thanks again for them.
In summary,
Hytec2992 SERIAL highway driver is only one used in EPICS.
If you don't limit at SERIAL highway driver,
Kinetic Systems 2917 K-Bus paralel interface board is also
used with EPICS.
Driver routines are avilable for EPICS collaborators.
>At one time, CEBAF also used the Kinetic Systems 2917 for
>its control system. The driver was written by Chip Watson at CEBAF.
>You can get the source code from ftp site at CEBAF:
> ftp.cebaf.gov:/pub/epics/camac/ks2917
>Or the lanl version at
> thoth.atdiv.lanl.gov:/pub/epics/camac.tar
>Johnny Tang Voice: (804)249-7239 E-Mail: [email protected]
>Continuous Electron Beam Accelerator Facility
>12000 Jefferson Avenue, MS 85A
>Newport News, Virginia 23606
According to Mr. Bjorkund, EPICS CAMAC device support which uses any of
the "Implementation-Dependant" features of the ESONE standard supplied by
camacLib.c. And It should be possible to use CAMAC dirver board if there is
a ESONE compliant dirver routine.
>I don't think there is anything in the CEBAF/LANL/Chicago EPICS CAMAC device
>support which uses any of the "Implementation-Dependant" features of the ESONE
>standard. The exception to this is the card-specific lam-grader module I
>currently include in the distribution.
>It therefore should be possible to load (for example) a CERN Camac library and
>run EPICS device support on top of it.
>This, of course, is an as yet unproven assertion.
>Eric Bjorklund Voice: 505-667-6031
>Los Alamos National Laboratory Email: [email protected]
>AOT-6 MS H820
>PO Box 1663
>Los Alamos, NM 87545
I used both CEBAF version and LANL version of camacLib with EPICS R3.12.2
and found both driver work fine.
In the test I needed to modify the definition of the structure ksc2917Regs
in ksc2917.h. I added 144bytes long pad at the
end of the structure and made the size of ksc2917Regs 256bytes long.
Without this modification, IOC cannot handle multiple KSC2917 boards
in a same VME subrack.
typedef struct /* ksc2917_registers */ {
uint16_t volatile cser; /* 00 -- Control Status/Error Register */
uint16_t volatile unused02; /* 02 */
uint16_t volatile docr; /* 04 -- Device/Operation Control Register*/
uint16_t volatile sccr; /* 06 -- Sequence/Channel Control Register*/
uint16_t volatile dlr; /* 6A -- Data Low Register */
uint16_t volatile dhr; /* 6C -- Data High Register */
uint16_t volatile csr; /* 6E -- Control Status Register */
uint16_t volatile unused70[72]; /* Padding */
} ksc2917Regs;
Thats all for today.
Noboru Yamamoto
KEKB Accelerator Control Group
KEK, JAPAN
Noboru Yamamoto
KEKB accelerator Control Group
KEK, Accelerator Dept.
JAPAN
- Re: [Summary] CAMAC Serial Driver watson
bug in VXI resource manager Jeff Hill
<1996>
<1996>
