1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: baseR3.13.0.alpha5
To: [email protected]
Date: Tue, 16 Jul 1996 09:51:06 -0500
I forgot to add some release notes. I updated WWW.
The additions are as follows:
dbStaticLib
The Following routines are now obsolete.
OLD ROUTINE             REPLACEMENT
dbFindRecdes            dbFindRecordType
dbFirstRecdes           dbFirstRecordType
dbNextRecdes            dbNextRecordType
dbGetRecdesName         dbGetRecordTypeName
dbGetNRecdes            dbGetNRecordTypes
dbFirstFielddes         dbFirstField
dbNextFielddes          dbNextField
dbGetChoices            dbGetMenuChoices
For now the old version will be supported. After one release they
will go away.
Janet forgot to update the base/README file.
The updated version is attached to this mail message
and will be added to bugs for alpha5.
Marty Kraimer
$Id: README,v 1.16 1996/07/16 14:18:48 jba Exp $
3.12 EPICS BASE Notes and Build Instructions.
	- By Matthew Needes
Notes:
1. Before you can build or really use EPICS, you must properly set the
   environemnt variable HOST_ARCH. The epics/startup/HostArch script file
   has been provided to set HOST_ARCH.
2. You must use GNU make (which is now THE supported make utility) for
   the build, gnumake.  Set your path so that a recent version (e.g.
   V3.70) of gnumake is available.
   Part 1 - Configuring and Building EPICS Base
1.1  To configure EPICS, edit the following files:
   config/CONFIG_SITE      - Build choices/HOST_ARCH/Vx location.
   config/CONFIG_SITE.*    - Location of X, etc.
   config/CONFIG           - For overriding specific variables.
1.2  To add a target architecture to EPICS:
   cd base/config
   cp CONFIG.mv167 CONFIG.YOUR_ARCH
   edit CONFIG.YOUR_ARCH   - For compiler flags / etc.
   cp CONFIG.Vx.68k CONFIG.Vx.YOUR_ARCH_CLASS
   cp CONFIG_SITE.Vx.68k CONFIG_SITE.Vx.YOUR_ARCH_CLASS
       - ONLY IF you are adding a new architecture class,
                 see note in Appendix A.
   edit CONFIG_BASE    - Add architecture to list.
1.3  To build EPICS:
   cd epics/base
   gnumake             - To build and install EPICS.
   gnumake clean       - To clean temporary object files.  Top level
                         clean will remove all the O.ARCH dirs, not
                         only those specified in BUILD_ARCHS.
   gnumake uninstall   - Only available at the top level directory.
                         Cleans directories created by the install.
1.4  "Partial" build commands:
   gnumake clean.sun4       - Cleans sun4 binaries in O.sun4 dirs only.
   gnumake install.sun4     - Builds sun4 only.
   gnumake install.mv167    - Builds mv167 only (a HOST_ARCH build must
                              be complete before this can be issued).
NOTES:
   1. EPICS binaries and shellscripts are installed into the directory
      $(INSTALL_LOCATION)/bin/ARCH.
   2. EPICS libraries are installed into the $(INSTALL_LOCATION)/lib/ARCH
      directory.
   3. During a normal build (a "make" or "make install"), the "depends"
      dependency will NOT be invoked.  Only if "make depends" is run
      explicitly, or a "make built_release" is performed will dependencies
      be generated automatically.
   4. Temporary objects are stored in src/DIR/O.ARCH, This allows objects
      for multiple architectures to be maintained at the same time.
      While developing source for EPICS, merely cd src/DIR/O.ARCH, and
      invoke "make":
      cd epics/base/src/db/O.mv167
      make dbAccess.o
      The above example instructs make to build dbAccess.o for the
      mv167 target.
   Part 2  ---  Configuration Files in epics/base/config
CONFIG - This file is meant to be included in the low-level EPICS Makefiles.
It includes the other EPICS makefiles, and allows individual developers
and the EPICS system manager to override specific variables in the rest of
the configuration.
CONFIG_SITE - This file is meant to be changed only by the EPICS system
manager.  It specifies:
	HOST_ARCH: The system's host architecture (sun4/hp700/etc).
               This now come from an environment variable.
	CROSS_COMPILER_HOST_ARCHS: List of unix architectures with cross_compilers.
	CROSS_COMPILER_TARGET_ARCHS: List of architectures to build epics for.
	VX_DIR: Location of vxWorks.
	STATIC_BUILD: Whether or not to build clients statically.
	etc.
CONFIG.ARCH - This file defines a particular architecture.  It
contains the following variables:
	BUILD_TYPE: Unix / Vx
 	ARCH_CLASS: 68k / sun4 / hp700 / etc.
	Architecture dependent build flags.  The flag names / contents
		depend on your architecture class.
CONFIG_SITE.ARCH - Contains site specific definitions pertaining to a
particular architecture.  This file's primary usefulness is to
define site specific compile and link flags.
CONFIG_COMMON - Contains definitions describing the layout of base.
CONFIG_BASE -  Defines what subdirectories get built by default under base.
RULES.Vx - Rules for building with VxWorks makefiles.
RULES.Unix - Rules for building with Unix makefiles.
RULES_TOP - Top level rules for building.
RULES_ARCHS
RULES_DIRS - Allows top-level type command syntax in low-level directories.
    Table of files to change when building and adding architectures.
	etc.
Filename                  SYS_MGR  ADD_VX_ARCH  ADD_UNIX_ARCH  DEVELOPER
CONFIG                       m         -             -             m
CONFIG_SITE                  m         m             m             -
CONFIG_SITE_ENV              m         -             -             -
CONFIG.ARCH                  -         c             c             -
CONFIG_SITE.ARCH             -         c             c             -
CONFIG.Vx.ARCH_CLASS         -         c*            -             -
RULES.Vx                     -         -             -             -
RULES.Unix                   -         -             -             -
CONFIG_BASE                  -         -             -             -
CONFIG_COMMON                -         -             -             -
CONFIG_ENV                   -         -             -             -
RULES_ARCHS                  -         -             -             -
RULES_DIRS                   -         -             -             -
RULES_TOP                    -         -             -             -
     m -  Modify an existing file.
     c -  Create a new file.
     * -  Create an ARCH_CLASS file only if you are adding a
             fundamentally new architecture, such as hp700 or
             a SPARC VME board.  If your board is 68k based,
             you will not need to create CONFIG.Vx.68k,
             since it already exists !
   Part 3  ---  Configuration File Inclusion Tree Examples
----------------------------  hkv2f example --------------------------------
            (files are numbered in the order of their inclusion)
 src/db/Makefile.Vx     (An example EPICS makefile)
    |   +--- 3.  RULES.Vx
    |              Default rules.
    +------- 2.  CONFIG
                  | | | +- 1. CONFIG_SITE
                  | | |             HOST_ARCH = sun4
                  | | |             BUILD_ARCHS = $(HOST_ARCH) mv167 hkv2f
                  | | |             VX_DIR = /vxworks
                  | | |             More.
                  | | +--- 2. CONFIG_COMMON
                  | |               General info about base.
                  | +----- 3. CONFIG.hkv2f
                  |           ^     BUILD_TYPE = Vx
                  |           |     ARCH_CLASS = 68k
                  |           |     Arch Specific Compiler Flag Setup
                  |           +---  a. CONFIG.Vx.68k
                  |                         Compiler/utility setup for ARCH_CLASS
                  +------- 4. CONFIG_SITE.hkv2f
                                    Site Specific setup
----------------------------  sun4  example --------------------------------
 src/db/Makefile.Unix   (An example EPICS makefile)
    |   +--- 3.  RULES.Unix
    |              Default rules.
    +------- 2.  CONFIG
                  | | | +- 1. CONFIG_SITE
                  | | |             HOST_ARCH = sun4
                  | | |             VX_DIR = /vxworks
                  | | |             More.
                  | +----- 3. CONFIG.sun4
                  |                 BUILD_TYPE = Unix
                  |                 ARCH_CLASS = sun4
                  +------- 4. CONFIG_SITE.sun4
                                    Directory locations
   Part 4  ---  EPICS makefile rules
 Rules supported by lower level Makefiles:
    depends		- Generate include dependencies
    build		- Builds objects, using libraries from "build_libs"
    install		- Installs executables in bin/ARCH
    clean		- Cleans objects
Prev: [no subject] Michael Bordua
Next: Stringin Record Jens Bergl
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
