1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Stringin Record
To: [email protected]
Date: Thu, 18 Jul 1996 18:26:58 +0200
I had a problem with Stringin records. When I set a monitor on the record, a
change of severity and status of that record were not posted to the ca
monitor. The reason for
that behaviour can be found in the record support of Stringin records. In the
function
monitor() there the function db_post_events() is only called, if there is a
difference
between the Value field (VAL) and the Old Value field (OVAL). The setting of
the alarm flag in the monitor_mask by recGblResetAlarms() doesn 't force a
call of db_post_events()
with set alarm flag!
For the Stringout record the situation is the same.
Jens
Jens Bergl		[email protected]
BESSY II
(030) 6392-4862 (FAX -4859)
Prev: baseR3.13.0.alpha5 Marty Kraimer
Next: serial port Stefan Hippler
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
