1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: COMMUNICATION between EPICS and the Allen Bradley SLC 500
From: Stephanie Allison (415)926-4534 <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Fri, 30 Aug 1996 9:32:12 -0700 (PDT)
>* The Equipment Protection System (EPS) Status will be sent to EPICS via a
>6008-SV1R VME Allen Bradley Remote I/O Scanner.  The scanner (i.e. a
>6008-SV1R) actually talks to the SLC 500 remote I/O via a Direct
>Communications Module (i.e. a 1747-DCM).
The communication between the PEP-II high voltage power supply system and
our RF EPICS system will be done in exactly the same manner.  We also use
the 16 bit binary device support and set up the the database using the
same formula as you.  In addition to binaries, we had the need to send and
receive analog values from HVPS so we developed devABANALOG.c (very similar
to devABBINARY.c) which provide device support for longins/outs and
analogins/outs and assumes 16 bit raw values.
This could be added to the standard distribution if anyone is interested.
Stephanie Allison  [email protected]
Re: COMMUNICATION between EPICS and the Allen Bradley SLC 500 Marty Kraimer
Prev: Hknitro60 + epics Greg Greene
Next: Re: COMMUNICATION between EPICS and the Allen Bradley SLC 500 Marty Kraimer
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Hknitro60 + epics John R. Winans
