1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Hknitro60 + epics
To: [email protected] (Greg Greene)
Cc: [email protected]
Date: Fri, 30 Aug 1996 13:22:48 -0500
>Are there any special configuration changes to EPICS or the vxWorks kernel
>when using the hknitro60?  We're getting access violations that appear
>to be related to interrupts when we start monitoring.  This might be
>a 68060-related issue.  I know that vxworks doesn't use separate interrupt
>stacks when a 68060 is used.
>I just want to make sure that I'm not tracking something that has already
>been addressed before.
What is 'monitoring'??
What addresses are you getting errors on?
Should these be otherwise valid addresses?
The stack stuff should be OK, I'd do a "checkStack" and "memShow 1" to
see if vxWorks is sane before and after these obscure IRQs.
I have run a software-only EPICS database on the nitro-60 using NO
other VME hardware in the crate and it appeared to run OK.  The only
reason for alterations to the vxWorks kernel would be determined
entirely by the other hardware you wish to use in the crate.
I am not entirely sure, but I believe that the A16 area to be safe
as-shipped.  Your A24 and A32 regions probably require some hackery in
the sysLib.c file.
--John Winans
Hknitro60 + epics Greg Greene
Prev: Re: COMMUNICATION between EPICS and the Allen Bradley SLC 500 Marty Kraimer
Next: Re: SNL exit question Jeff Hill
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Hknitro60 + epics Greg Greene
Next: RE: COMMUNICATION between EPICS and the Allen Bradley SLC 500 415
