1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dm colour rules with -ve values
To: [email protected], [email protected]
Date: Fri, 13 Sep 96 14:43:30 MDT
This message is pertinent only to those of you using edd/dm 2.0 or later.
David wrote:
> I'm trying to use dm colour rules to change the colour of a text monitor
> according to the value of a database field of type double. For values of
> 0.0 or greater this works fine but I can't get it to work with negative
> values; it behaves as if the expression is always false.
> The rule in the edd report looks like:
>                 name="test"
>                 info[0] {
>                         chan="$(C)"
>                         value="-1.0"
>                         connector="use"
>                         comparator="less than"
>                         clr="1"
>                         RISCpad="0"
> Should this work ? If not, is there any other way of doing what I want ?
Yes, it should work.  Unfortunately, as David reported, it doesn't!
To fix it, look in rti/dynamic_graphics.c and apply the following change:
int evalColoRule( valStr, pComel, comparator)
        if(isdigit(*valStr)){
change the last line to be
        if(isdigit(*valStr) || *valStr == '-'){
This is a quick fix, but I've tested it and it works.  I'll try to rework
the color rule comparisons soon and will come up with something better.
Thanks, David.  I'm not surprised there was a bug, but I'm surprised it
took so long for someone to notice :) !
Deb
Deb Kerstiens		[email protected]
Phone			(505)667-3396
LANL AOT-8,MSH820	PO Box 1663, Los Alamos, NM. 87545
Prev: Re: A tool to support development of GP-IB device support routine. Noboru Yamamoto
Next: Re: A24 DMA into the hk nitro 60 Nick Rees
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dm colour rules with -ve values Deb Kerstiens
Next: Re: CA connection Jeff Hill
