1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "bad client read io id from server" message
To: William Lupton <[email protected]>
Cc: [email protected]
Date: Mon, 23 Sep 1996 15:04:48 -0600
William Lupton wrote:
>   The problem is a fatal "bad client read io id from server" message
> (from the CA client library) which then, I believe, unconditionally
> calls abort().
This bug was fixed last fall in CVS tag epics_R3_12_1_3 (created on
1995/09/29). I suspect that the application code is linking against a
version of the the CA client library created prior to this date.
The solution is to relink the client against a more recent version of EPICS.
Sorry about the any grief that this has caused.
Jeff
PS: Here are some of the original bug reports on this problem:
> Chris,
> > A CA client application is giving the message:
> > "Message: Channel Access Internal Failure"
> > "Severity: Fatal"
> > "Context bad client read io id from server"
> > Unfortunately, this seems to be an intermitent failure
> > that happens a few times a day while the client is polling
> > some PVs.
> > If you have any additional info. on this message, I'd like
> > to know.
> After a quick look in the source I see that this problem exists
> in 3.12.1.1 and is fixed in 3.12.2.1. The problem was discovered
> by Fred Vong at APS and was related to a race condition where
> the CA client lib receives a message for a particular resource
> (a channel or a monitor) shortly after that resource was deleted.
> Fred,
> > The first one is that the channel acccess still calls my connection event handler
> > and access right handler after I call the ca_clear_event() and ca_clear_channel().
> > The above unexpected callbacks only happen when you call ca_clear_event() and
> > ca_clear_channel() during the IOC reboot but before the channel access prints
> > out the lost connection message.
> This is a bug. It will show up under the following circumstances:
> o The client has a valid connection to an IOC
> o The client deletes a channel on that IOC
> o The IOC disconnects prior to returning its delete confirm message
> > Calling ca_change_connection_event() with a NULL handler solves the first problem but
> > calling ca_replace_access_right_event() with a NUll handler results as a segmentation
> > fault.
> This is also a bug.
> It will occur only if you attempt to set the access rights handler to NULL.
> > The second one is that the channel access calls my event handler with args.dbr = NULL.
> > This happens during I am doing a lot of connections, disconnections, ca_add_event()
> > and ca_get_callback().  The debugger shows args.dbr = NULL.
> This isnt a bug.
> This would occur during normal operation if the status in struct event_handler_args
> wasnt ECA_NORMAL (indicating the the requested operation failed in the IOC) or if
> there isnt any data returned (ie put call back).
> An example of an operation failing in the IOC would be attempting to
> read an ai PV that is in INVALID alarm because the hardware isnt present.
> You would also be called back with a NULL dbr pointer and status equal to
> ECA_DISCONN if a get call back was outstanding and the IOC disconnected.
> There are omissions in the document in this area and I have eliminated
> them (but not updated the web yet).
> Code changes for all of the above will show up in EPICS 3.12.2.
> Thanks for your assistance tracking down these problems.
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: EPICS Power PC board. Noboru Yamamoto
Next: unsubscribe Thomas Dean
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Accessing EPICS Software Distribution Bakul Banerjee
