1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RS232 Configuration Question on MVME162
To: [email protected]
Date: Tue, 05 Nov 1996 14:34:33 EST
--- Begin Message ---
Epics users:
Is there a way to set parity (none, even, odd) on a 162
serial port running vxworks 5.2?  I see how you can set
just about everything else using "ioctl" but not parity.
I have a power supply that requires "even parity".
I know that there is an option (OPT_7_BIT) to strip the parity bit
on incoming data but no way of transmitting with even parity.
Also, has anyone written any software to communicate to
General Dynamics DC Power Supply
Model Number PD42-04000103-GKLX-PY57
We received this supply from the SSC and it has limited
documentation and no test software.
Thanks in Advance
 ______________________________________________________________________
| Scott Higgins                    *   Telephone:                      |
| Machine Control Center, MS 85A   *   (757) 269 7411 (Work)           |
| Thomas Jefferson National        *   (757) 680 7411 (Pager)          |
|    Accelerator Facility          *   (757) 269 7049 (Fax)	       |
| Newport News, Virginia 23606     *   E-mail: [email protected]       |
|______________________________________________________________________|
--- End Message ---
Prev: Re: Alarm conditions ? Ned Arnold
Next: seqChanShow switches Sean Prior
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: RS232 Configuration Question on MVME162 John R. Winans
