1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RS232 Configuration Question on MVME162
To: [email protected], [email protected]
Date: Wed, 13 Nov 1996 07:10:10 -0600
> Is there a way to set parity (none, even, odd) on a 162
> serial port running vxworks 5.2?  I see how you can set
> just about everything else using "ioctl" but not parity.
> I have a power supply that requires "even parity".
> I know that there is an option (OPT_7_BIT) to strip the parity bit
> on incoming data but no way of transmitting with even parity.
The source to the tty driver for the mv162 seems to only cover the
baud rate in its hardware-specific portion.  If you are REALLY stuck, you
can cheat by accessing the 8530 serial controller directly or adding the
proper IOCTL code to z8530Serial.c in you vxWorks distribution and
recompiling it.  Either way, you will want to use the 8530 driver as
an example of how to use the chip.
FYI -- I have a note here about a patch from wind rivers about the serial
controller.  I don't recall the details, you might want to contact them
about it.  I seem to recall something about the LX board being different
and/or broken.  I don't want to start any panics here, contact WRS first...
I don't recall the details.
--John Winans
Re: RS232 Configuration Question on MVME162 Graham Waters
Prev: Help w/PulseTrain and PulseCounter using Mizar 8310 board Tien Doan
Next: Re: Help w/PulseTrain and PulseCounter using Mizar 8310 board Marty Kraimer
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RS232 Configuration Question on MVME162 Charles Scott Higgins
Next: Re: RS232 Configuration Question on MVME162 Graham Waters
