1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VME: Cannot find record type dfan
To: [email protected]
Date: Fri, 13 Dec 1996 20:45:55 +0100 (MET)
On Thu, 12 Dec 1996, Rozelle Wright wrote:
# > Hi,
# > During my development process I wanted to use Data Fanout record (1st
# > time). When I tried to down-load database to the VME an error message
# > appeared:
# > Cannot find record type dfan
# > Cannot create record E:aa_dfan
# > Cannot find field DESC
# > Cannot set field DESC to data fanout record
# > Cannot find field SCAN
# > Cannot set field SCAN to Passive
# > Cannot find field PINI
# > Cannot set field PINI to NO
# > Thanks in advance for any suggestion.
# > Regards,
# > Marian Zurek
# > Marian Zurek
# > CERN
# Are you using capfast?   If so you may have an old version of the
# symbol library.  In the symbols edfan.sym and edfans.sym
# you should have Type:dfanout.
# Some of the older versions had Type:dfan.
# and edb.def also matches them with
# (RECORD "edfan" "edfans" "edfanm"
#         (Type "dfan")
# For the fanout record this should be declared as
#       (Type "dfanout")
# I checked with the version currently at APS and found that it has this
# problem also.
# I will discuss with Bakul how to deal with distributing symbol libraries.
# Right now, I think LANL and the astronomy community have the same library,
# but CEBAF may have a different one and APS is a slightly older version
# of LANLs.
# In the meantime, you could simply edit the symbols and edb.def and
# fix them.
I did what You suggest above but it still doesn't work.
Messages from the VME:
Cannot find field INP
Cannot find field SEL
Cannot find field A
Cannot find field B
Cannot set field HOPR to 0.000000000000000e+00
Cannot set field LOPR to 0.000000000000000e+00
It looks that I have 'wrong' database definition for Capfast (?)
Marian Zurek
Marian Zurek
CERN
Prev: Re: IP support Peregrine McGehee
Next: Serial and GPIB IP's and IP Carriers Ernest L. Williams Jr.
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VME: Cannot find record type dfan Rozelle Wright
Next: Re: VME: Cannot find record type dfan Rozelle Wright
