1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Serial and GPIB IP's and IP Carriers
To: [email protected]
Date: Fri, 13 Dec 1996 14:13:04 -0600
I am one of the APS beam line users responsible for beamline controls.    I am in the market for a nice GPIB
RS232/RS485 VME-based solution running under EPICS only.
For my application HIDEOS is too much overhead.  I think HIDEOS is an excellent system but its use, of course,
is application dependent.
I am currently using an IP carrier from SYSTRAN Corporation.  This carrier is much better than Green Springs
especially from a hardware and software perspective:
1.  Has 5-IP slots as opposed to 4
2.  Cost per IP slot is cheaper
3.  Reset IP cards on the fly with the reset register
There is a lot more, however, I'll just reference their home page (http://www.systran.com)
I am currently using an 8-channel DAC daughter card (i.e. DAC128V IP card) from Systran.
I thought the DAC128V was supported under EPICS.  I found out later that only if you have HIDEOS.
The way that I am talking to my IP DAC is via the VME record developed by Mark Rivers (CARS-CAT).
So I am in dire need for a more permanent solution.
Is anyone using the GPIB 1014 by National Instruments under EPICS?
Ernest L. Williams Jr.
MHATT-CAT
APS
(630) 252-0209
Prev: Re: VME: Cannot find record type dfan Marian Zurek
Next: Re: Serial and GPIB IP's and IP Carriers Mark S. Engbretson
Index: 1994  1995  <1996>  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS supported Power Supply controllers Ralph Lange
