1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with Alh & Channel Access (R3.13.0b4).
To: Nick Patavalis <[email protected]>
Cc: [email protected]
Date: Mon, 03 Mar 1997 15:27:38 -0700
Nick Patavalis wrote:
> The crash happens durring the conversion from net to host
> format. Specifically when the "cac_dbr_cvrt[]" array is de-referenced
> and the outcome (function ptr) executed. When the crash happens the
> code reaches there with:
>         piiu->curMsg.m_type == 37
> Since there are but 34 function pointers in the  "cac_dbr_cvrt[]"
> array (as initialized in "convert.c"), crashing is unavoidable!
As Mark Rivers mentioned, there was a problem in R3.13 occurring
when all of the following were true (fixed in R3.13.beta5).
o IEEE native floating point format
o double precision operand
o little endian host
o source and destination address for conversion are identical
However, on the surface this does not appear to be the same
problem because:
o The data item that is incorrect is a 16 bit unsigned integer
o Many other programs are working {medm, probe, ...} on this
platform (and they use data type codes).
Possible causes of out of range data type code:
o some code is writing on the CA client's internal data structures
o CA protocol is being read missaligned. We have not seen this.
Causes we dont expect:
o ALH using the wrong data type code (this is checked by
the client lib and also by the server)
I dont have much to go on. Perhaps the floating point problem
is causing corruption to occur (seems unlikely).
We will need to reproduce the problem. Since I dont
have a lynux system set up here perhaps you can provide
a remote login (and access to -g compiled object code).
Do the symptoms (location of the crash) change if you
rearrange the configuration for ALH. Has anyone else used ALH
under lynux before?
> I just looked at the APS, WWW server, and the most recent release is
> R3.13.0beta6. I supose this won't do the trick....
beta6 has the fix for the double precision/ieee/liddle endian
problem.
> I also wonder if there is any documention on channel access other than
> the the... elementary "channel access reference", which only contains a
> short description of the function calls.
A CA tutorial that is less ... elementary is in the works :)
> Is there a Channel Access
> _Protocol_ reference? If so where I can look for it?
No such critter exists. Depending on funding, a simple protocol
document may be a product of the design cycle for CA V4.
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Re: Problems with Alh & Channel Access (R3.13.0b4). Nick Patavalis
Prev: Solaris 2.5.1 include problem Steve Lewis
Next: Problems with Alh & Channel Access (R3.13.0b4). Nick Patavalis
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problems with Alh & Channel Access (R3.13.0b4). Nick Patavalis
Next: Re: Problems with Alh & Channel Access (R3.13.0b4). Nick Patavalis
