1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with Alh & Channel Access (R3.13.0b4).
To: [email protected]
Cc: [email protected]
Date: Tue, 4 Mar 1997 21:41:49 +0200 (EET)
On  4 Mar, Jeff Hill wrote:
> I dont have much to go on. Perhaps the floating point problem
> is causing corruption to occur (seems unlikely).
> We will need to reproduce the problem. Since I dont
> have a lynux system set up here perhaps you can provide
> a remote login (and access to -g compiled object code).
Certainly! You will receive a message about the details.
> Do the symptoms (location of the crash) change if you
> rearrange the configuration for ALH. Has anyone else used ALH
> under lynux before?
All I use is a minimal alh configuration file. Here it is:
GROUP NULL TOP
CHANNEL TOP ai1 ---TL
and my database (the only one on the network) contains no more than a
soft periodic ai record named "ai1".
If I use a diferent alh config file, the location and the apparent
reason for the crash still remain exactly the same!
Sincerely
Nick Patavalis
Nick Patavalis               Snail-mail:
([email protected])         Thironos 11,
University of Athens,            161 21 Athens,
Computer Science Dept.           Hellas.
Re: Problems with Alh & Channel Access (R3.13.0b4). Jeff Hill
Prev: MVME177 and vxWorks Jim B. Kowalkowski
Next: VxWorks file i/o problem Len Lawrence
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problems with Alh & Channel Access (R3.13.0b4). Jeff Hill
Next: RE: Problems with Alh & Channel Access (R3.13.0b4). Nick Patavalis
