1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stack overflows
To: David Terrett <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 19 Mar 1997 09:38:53 -0700
David Terrett wrote:
> I have just discovered the VxWorks "checkStack" command and find that
> after loading my system, bringing up a couple of dm screens and setting a
> couple of process variables one of the lines of output from checkStack
> reads:
> CA client    _camsgtask   fff138    4760   264  4760      0 OVERFLOW
> Should I be worried by this ? If so, what can I do about it ?
Yes, this indicates that your stack has grown past its allocated space
and
it will therefore be corrupting other data structures in memory. This
of course could result in a system crash.
> I also believe that I am overflowing the stack in a subroutine attached to
> a subroutine record that is being scanned periodically. How can I increase
> the stack for a scan task ?
> (I am using Epics 3.12.2)
Most likely this is caused by an unusually long string of
interconnected records in your database. When the server
(running in camsgtask) calls db_put_field() for a passive
record recursive record processing results, and this can
overflow the stack if you have a very long string of
interconnected records.
In the latest patch release or R3.12.2 the file
"$(EPICS)/base/include/task_params.h" has the following
parameters in it:
#define CA_CLIENT_STACK         10000
#define EVENTSCAN_STACK         10000
#define SCANONCE_STACK          10000
#define CALLBACK_STACK          10000
#define PERIODSCAN_STACK        10000
You might find that bumping your copy of CA_CLIENT_STACK
to 10000 resolves your problem (after you rebuild
the object codes in base and reboot the IOC).
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Stack overflows David Terrett
Prev: Stack overflows David Terrett
Next: test Russell J. Page, Sr.
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Looking for help Todd Boroson
