1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Compilation error in EPICS extension
To: [email protected], [email protected]
Date: Wed, 26 Mar 1997 10:46:29 -0600
> I am attempting to Make the EPICS R3.13.0.beta4 extensions. When I get
> to appSR, I get the following error that I have encountered both single
> and double colon entries in the rule. I understand the difference, and
> have infact fixed this type of error before. My problem is I can't find
> the error. Here is part of the make output that contains the error
> message:
The old appSR extension is no longer supported in EPICS R3.13.  It should
not be built with any version of EPICS R3.13.  The appSR extension creates
a whole set of tools to be used with the pre R3.13 application directory
structure. These tools need the default.dct and default.dctsdr files which
no longer exist and have been replaced by the new ascii *.dbd files in R3.13.
Remove "appSR" from the extension list in the CONFIG_EXTENSIONS file so that
it no longer tries to build.
The new application directory structure and the new tool makeBaseApp are
described in "Application Developer's Guide R3.13.0.Beta4" which is on the
APS EPICS web page under EPICS Documentation.
Starting with beta7 a new document "IOC Applications: Building and
Source/Release Control R3.13.0beta7" is available. (See EPICS Documentation,
CODE Development on the web) Note that the beta7 version of makeBaseApp is
slightly different than for beta4.
Sorry for the inconvenience that this problem has caused you.
Janet
Prev: RE: Problem of monitoring 15,000 channels within EPICS Matthias Clausen DESY -MKS-2/KRYK-
Next: INC and install Russell J. Page, Sr.
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Compilation error in EPICS extension Lancaster, Christy A
Next: COllaboration Meeting In Vancouver Bob Dalesio
