1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Compilation error in EPICS extension
To: "'tech-talk'" <[email protected]>
Date: Tue, 25 Mar 1997 09:11:33 -0800
I was having the same problem till I discovered that the commands for
build and install (which you will find has problems in some directories)
are duplicated between certain Makefile.Unix's and the RULES_ARCHS in
the config directory.  There is a new set of extensions and config files
available as of mid-March that seem to resolve this problem.  In the
meantime, if you want to fix the problem, comment out the build
statement in the Makefile.Unix and things should progress normally.
Good luck!
Christy Lancaster
Boeing Free Electron Laser
PO Box 3999 M/S 2T-50
Seattle, WA  98124
(206)544-5426
>From: 	Russell J. Page, Sr.[SMTP:[email protected]]
>Sent: 	Tuesday, March 25, 1997 7:07 AM
>To: 	Tech_Talk
>Subject: 	Compilation error in EPICS extension
>Hi:
>I am attempting to Make the EPICS R3.13.0.beta4 extensions. When I get
>to appSR, I get the following error that I have encountered both single
>and double colon entries in the rule. I understand the difference, and
>have infact fixed this type of error before. My problem is I can't find
>the error. Here is part of the make output that contains the error
>message:
>gnumake[2]: Leaving directory
>`/home/locus/epics/R3.13.0.beta4/extensions/src/alh'
>/usr/local/bin/gnumake -C appSR  inc
>gnumake[2]: Entering directory
>`/home/locus/epics/R3.13.0.beta4/extensions/src/appSR'
>/usr/local/bin/gnumake -C O.sun4 -f ../Makefile.Unix T_A=sun4 inc
>gnumake[3]: Entering directory
>`/home/locus/epics/R3.13.0.beta4/extensions/src/appSR/O.sun4'
>../Makefile.Unix:190: *** target file `build' has both : and ::
>entries.  Stop.
>gnumake[3]: Leaving directory
>gnumake[2]: *** [inc.sun4] Error 2
>gnumake[1]: *** [appSR.inc] Error 2
>gnumake[1]: Leaving directory
>`/home/locus/epics/R3.13.0.beta4/extensions/src'
>gnumake: *** [src.inc] Error 2
>Note that it indicates line 190 of Makefile.Unix. Note below that
>(according to my editor) 'build' occurs in line 188, not 190. I am
>however looking at everything I see connected to either line. Refer now
>to the appropriate segment of the makefile:
>INSTALL_APPSR=$(INSTALL_LOCATION_BIN)/appSR
>APPSR_INSTALL_DIRS=$(APPSR_DIRS:%=$(INSTALL_APPSR)/%)
>APPSR_INSTALL_PROD=$(APPSR_PROD:%=$(INSTALL_APPSR)/bin/$(T_A)/%)
>APPSR_INSTALL_TOOLS=$(APPSR_TOOLS:%=$(INSTALL_APPSR)/bin/$(T_A)/%)
>APPSR_INSTALL_FILES=$(APPSR_FILES:%=$(INSTALL_APPSR)/%)
>APPSR_INSTALL_SCCS_FILES=$(APPSR_SCCS_FILES:%=$(INSTALL_APPSR)/%)
>include $(EPICS)/base/config/RULES.Unix
>build: $(APPSR_PROD)    <-------------------------- flagged as error
>install: $(INSTALL_LOCATION_BIN) $(INSTALL_APPSR) $(APPSR_INSTALL_DIRS)
>$(APPSR_INSTA
>LL_TOOLS) \
>$(APPSR_INSTALL_PROD) $(APPSR_INSTALL_FILES) $(APPSR_INSTALL_SCCS_FILES)
>appSRLinks
>$(INSTALL_APPSR) $(APPSR_INSTALL_DIRS) $(INSTALL_LOCATION_BIN)
>        @mkdir $@
>I have looked everywhere I can think to find that double : entry, to no
>avail. Any thoughts ?
Prev: COllaboration Meeting In Vancouver Bob Dalesio
Next: Time granularity in archive data streams Matt Bickley
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Compilation error in EPICS extension Russell J. Page, Sr.
Next: Compilation error in EPICS extension Janet B. Anderson
