1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cdev & CORBA
From: Matthias Clausen DESY -MKS-2/KRYK- <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Wed, 9 Apr 1997 16:10:14 +0200 (MET-DST)
At last also some comments from my side...
cdev , CORBA , CA
How do they fit together or could any replace the other?
The question is - as in many cases - what type of functionality do your need from your
network layer and what are the performance requirements?
At first CORBA does not provide such a complex functionality like cdev but it come close
to it. CORBA solves the problem of distributed object (or services) over a heterogenious
environment of different operating systems. Where an object is not ment to be a (EPICS)
channel but more likely an IOC could be an object providing a special service like
'power_supply_controls'. In this case any CORBA client can talk to this server providing
this service and talk to the channels which are available under this service. You could
have another service i.e. 'vacuum' on the same (IOC) server which provides these channels.
The way you exchange the data is up to you. You'll implement your data exchange routines
i.e. get,set,get_name,get_history... Since you are using CORBA the problem of data
conversion is handeled by the CORBA implementation for the specific platform. So client
and server programs can be 'easily' written.
Norihiko Kamikubota from KEK was working on such an implementation here at DESY and
fortunately he finished the work for exchanging data between different platforms for a set
of routines which provide the services to exchange float,int,historical data, names,
strings etc. . Currently this implementation lacks in functionality in one point that
there's currnelty only one service on each server possible. Which is a problem of the
current implementation but not of CORBA itself.
So CORBA helpd to solve the following problem:
Data exchange betreen different platforms (like RPC with XDR)
Resolving the location of services on the net (through the CORBA broker)
The latter is the reason why initial connections through CORBA take longer that normal IP
connections. The throughput of CORBA connections though can - in special cases - be even
better than IP RPC connections. -> refer to Nirihiko
Result:
Can CORBA replace CA - no way! because of the response time (even though the complex data
types are still on the whish list!)
Can CORBA replace cdev - well in fact the cdev object definiton and the client-oriented
API are much different from the CORBA client/server approach. A CORBA service under cdev
would really make sense and it would be good if we could agree on the functions we will
implement and support under the cdev/CERBA service. In such a case more common services
could be implemented and - of course - shared.
For more informations about Nirihiko's work please have a look at:
http://herao1.desy.de/cc/www/help/help_corba.html
Please let me know if this page is locked for public.
Matthias
Prev: calcAo CAPFAST symbol and .edf file SAA
Next: Re: NFS mounting and channel access Jeff Hill
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cdev & CORBA Steve Hunt
Next: Re: cdev & CORBA Chris Timossi
