1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: SGL encoder in EPICS
To: [email protected]
Date: Mon, 7 Jul 1997 17:25:14 -0600 (MDT)
At LANSCE, we use the Kinetic Systems 3924 serial lam grader, which just sets
the slot number of the module in the demand message.  In our system, we are not
too concerned with prioritizing the LAM's, but if we were this means we would
have to arrainge our modules so the highest priority LAM was in slot 1, the
next lowest in slot 2, etc.
The camac software (/Epics/camac.tar) at our anonymous ftp site
(thoth.atdiv.lanl.gov) contains (in the /dev directory) the device support
routine (devLgCamacK3924.c) for the KS3924.  We don't really have a "lam grader
record", but instead use the routine, k3924_LamGrader (called before iocInit)
to declare the crate & slot numbers of all the lam graders, so that they will
be initialized as part of the crate setup.
Hope this helps.
Eric Bjorklund				Voice: 505-667-6031
Los Alamos National Laboratory		Email: [email protected]
AOT-6 MS H820
PO Box 1663
Los Alamos, NM 87545
Prev: Re: Bad CALC record kills IOC Tim Mooney
Next: Re: CPU speed on mv162/167 Andrew Johnson
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: SGL encoder in EPICS Noboru Yamamoto
Next: going mad with Capfast / e2db William Lupton
