Benjamin Franksen wrote:
> Hello everybody,
> I propose a (minor) change to the next EPICS release. Current problems
> with the new lanGpib driver suggest that an entry in the InitHooks
> function should be made in that calls the driver at some later point
> during IOC init. So far so good. But in our control system there are
> already some standard entries in this InitHooks function. And InitHooks
> only exists once.
> So what one does is to 'ifdef' parts of InitHook depending on what has
> to be called on each IOC. In my point of view this is ugly and
> contradicts the modular design of EPICS which otherwise allows each IOC
> to be configured individually by modifying the startup file while
> keeping the common base functionality consistent.
> Solution: A function
> void registerInitHook(void (*hookFunction)(int))
> callable (multiple times) from the startup file before iocInit. It
> chains together a series of initHook functions.
Note that you can do this without changing base. Just provide a routine:
void initHooks(int callNumber) {localInitHooks(callNumber); }
and let localInitHooks do what you suggest.
Marty Kraimer
- Re: InitHooks Benjamin Franksen
- InitHooks Benjamin Franksen
RE: InitHooks Jeff Hill
RE: Building EPICS on HP_UX 10.2 Noboru Yamamoto
<1997>
Re: Building EPICS on HP_UX 10.2 Ralph Lange
<1997>
