1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VXStats - cpu usage incorrect
To: [email protected]
Date: Mon, 18 Aug 1997 13:48:27 -0500
Andy Foster (Royal Greenwich Observator)
reported that devVXStats reports cpu usage
incorrectly. I ran a test case and agree
with Andy.
It is using sysClkRateGet in a place where
it should use the spy sample rate.
By default it uses a spy sample
rate of 80 Hz . Thus if the vxWorks clock
is 60Hz it overstates cpu usage by 80/60 = 1.333.
In looking at code it is also reporting file descriptor usage
not tcp connections.
This code needs to be looked at carefully before the next
base release.
Marty Kraimer
Prev: Re: VxWorksp2 is ready now! Bakul Banerjee
Next: edd/dm fonts Rolf Keitel
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Getting macro substituted channel names in sequences Ron Chestnut
