1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Getting macro substituted channel names in sequences
To: [email protected]
Date: Thu, 14 Aug 1997 10:08:10 -0700 (PDT)
I have an application where a sequence is started with either of two station
names, i.e. the macro name STN is substituted as either HB60 or LB60. Some
channels are mapped to BIT-3 shared memory and some private data in some of those
records is needed to map some (non channel) structures appropriately.
I see a way to use the macValueGet call to get the appropriate substitution for
STN, and can generate the name from that. However, the interesting data in the
seqChan structure generated by the sequencer holds, among other things, the
channel name. The correct name can be indexed through the value obtained from
pvIndex. This name is, unfortunately, not a "macro substituted" name.
When looking at attached channels with seqChanShow, both the raw and substituted
names are shown. Is there a simple (even if undocumented) call which will return
the substituted name?
Thanks.
/Ron Chestnut
Prev: RE: CA Server and CA Gateway Jeff Hill
Next: Re: VxWorksp2 is ready now! Arun Bommannavar
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: VXStats - cpu usage incorrect Marty Kraimer
